Temperature change since installation of PCM?
HighDesertRam
Utah
Cummins Diesel
In December I received the recall notice regarding the PCM valve that was never installed in my 2022 RAM 2500 with the Cummins engine. I had the recall service performed on January 2. I routinely drive my truck with the display that shows the coolant temperature, transmission temperature, and oil temperature selected on the dash. I've noticed that the temperatures are running significantly cooler than they have in the past by about 10-15 degrees. I'm not concerned about this, but just curious if this has anything to do with the PCM valve finally being installed?
06 Dodge
Forest Grove, Oregon
6.7L CTD
What was the recall number?
