Testing Factory Radio - amp draw
pauley05
New hampshire
Hi everyone,
Looking for some insight here. Chasing a parasitic drain on my 09 1500 big horn. Radio (m39) fuse is pulling over an amp. I have removed connector on the back side of the Radio and confirmed draw on battery drops to about .4amps. It is the factory P68021163AE Radio. Is there a way to test the Radio itself or is it best to just get a new one and throw it in? I don't believe anything in the harness would be bad as I never had any Radio issues but maybe somebody has had a similar situation!
Also it just happened randomly one day where the truck was dead after sitting for a few days.
Thank you
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Down in the Bottom Right Corner
down by the AUX port
there are 3 letters, first letter will be an R
Let us know what they are
I think it may be an RES 130 Hi Speed radio
if it has a Phone button & SAT button, that would make it a RESs 130 High Speed radio
High Speed refers to the CanBus speed
chopperman1
2018 Rebel
5.7L HEMI
Did you allow at least 20 minutes for the sleep cycle of the radio? A better way to test for parasitic draw is to use an amphound. It goes in parallel the fuses. When using an inline amp meter you have to wait out the sleep cycles which can drastically vary.
P
pauley05
New hampshire
I was not aware there was such a long sleep cycle for the radio. When I initially tested the draw it was after the truck sat for a day with the negative disconnected but I will test it again to be sure!
