The "lightning bolts" warning lights come on and my truck goes into limp mode.
stringring
The "lightning bolts" warning lights come on and my truck goes into limp mode. Sorry if this is long winded, but it's the only way I can explain this problem.
I was getting ready to do an over 3000 mile trip in my 2003 Dodge Ram 1500 with 5.7 hemi. My gas mileage had been about 12 mpg, so I changed the spark plugs and cleaned the throttle body. We headed out on our trip and I noticed that I was now getting 18 mpg, which was great! The truck was running fantastic! We had gone about 350 miles on I95 doing about 70 mph when all of the sudden the engine dropped of into limp mode and the lightning bolt signal came on. I'd never seen that and was kind of freaked out. I worked my way to the shoulder and turned off the truck. I checked the truck manual to find the lightning bolts meant the issue was related to the throttle control sensor. I turned the truck back on to see what would happen. The truck went back to running fine and we managed to drive another 40 miles to our days destination in Savannah, Ga. I did some research online when we got to our hotel room. Everything I read seemed to lead to throttle body sensor issues. I found that on my truck that the sensor was incorporated in the throttle body. I figured that I needed to address this issue by replacing the throttle body. I located a new throttle body and went to the parts store to pick it up. The truck was still running fine. As I headed to parts store, my check engine light came on. I plugged in my OBD2 scanner and the code PO441 EVAPORATIVE EMMISSION CONTROL SYSTEM INCORRECT PURGE FLOW came up. I tightened up the fuel cap and erased the code and the check engine stayed off. The parts guy told me to do this or it might be the purge valve. I went back to the hotel and installed the new throttle body and went through set up procedure. All went well and the truck ran great. We got on the road again and after about 40 miles the lightning bolts came back on and the truck went into limp mode again. I pulled to the shoulder, turned it off then back on and it ran fine. I got to a rest area and called the parts store and told them the issue. They said it could be a faulty part and I could return it for another. ( My gut feeling was that this wasn't a faulty part ) so they found one in a parts store along our way in North Carolina, about an 80 mile drive from where we were. I drove to that part store without issue. I installed the second throttle body. We drove about 200 miles without an issue. I figured the problem was solved. We stopped at a rest area and turned the truck off. We got back in the truck and drove, staying in the right lane and after about 80 miles the lightning bolts came back on. Turned it off and on and then made it to our destination in NJ. Long story short, we made it back to Florida and had the lightning bolt issue happen 4 times over the 1200 mile trip home. One time along the way, the check engine light came on with PO441 code and then the lightning bolts came on. When I got home, I replaced the purge valve. I've only been using the truck to drive around town, but the issue happens every once in a while. This has been a great truck and this is very frustrating. Any help would be greatly appreciated!
Thanks for reading this!
Bills86e
tampa bay
5.7L Hemi Longbed
PCM faulty. I got mine from Flagshipone.com $228 shipped.
I cannot properly diagnose, so it will send out all kinds of DTCs. remove it and send them the part # on your faulty pcm, then chuck it.
gamjunior
the burg
Was curious if you have got this issue fixed and if so what was it that fixed the issue. I am having the same issue but my 04 has not thrown. Been running just great then all of the sudden driving into work one morning I was at a light started to drive and it started bucking like a bull and the red throttle body lighting bolt was on. Pulled over shut it off and cranked right back up and got me home with no issues. The next day same thing.
rgloede
I recently had the dreaded lightning bolt. New throttle body and new gas pedal . It came on once since. It was a misfire in cylinder 4. Cleared it, hasn’t been back in 3 weeks.
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, True Blue Pearl
Unfortunately the OP seems to be another one of our one-post
wonders as they haven't been back since...
stringring
Junior Member · 71 · From Florida
Joined Feb 1, 2024
Last seen Feb 1, 2024
S
stringring
Sorry, I didn't receive any notification that anybody responded to this thread. Just checked in. No I haven't resolved this issue. It was suggested by someone not on this forum, that the problem is caused by a faulty APPS -Accelerator Pedal Position Sensor. Unfortunately Dodge has discontinued the part and the auto parts stores don't carry it either. I saw an after market one online for $400. I also found that it is a Mercedes part. I checked on a Mercedes match up, about $50. It is pretty much the same, except for the 6 pin plug configuration. I found one on a junked 2003 pickup like mine. I installed it. The same issue occurred after about 50 miles driving. I've heard some folks say it's in the wiring. Very frustrating
S
stringring
Sorry, I never got alerted that anyone responded to my post. Thanks for the response
S
stringring
S
stringring
S
stringring
S
stringring
