Tire size
Braden04
Hammond, LA
2013 ram 1500 4 door 2wd
2/4 drop… I bought rims 22x10. What tires size is suggested with 0 rubbing.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
Hopefully you measured your ride height before and after. This will give you an idea how much ride height you took out of your suspension.
You want to make certain with 10 wides you get the correct tire width.
285 45 22 are 32 inches tall and usually wil not rub on a 2/4 drop. Running a 22x9 rim.
285 40 22 are 31 inches on a 22x9 rim and will not rub on a 2/4 and will allow for you to go to a 3/5 or 4/6 when you are ready.
285 35 22 are 30 inches on a 22x9 rim . You give up quite a bit of sidewall, with this tire. It will not rub on a 2/4.
Based on lowering multiple trucks, the 285 40 22 would be where I would start. You could go down or up if you want based upon how much you want to fill the fender well. Use a tire conversion tool online to adjust . It really your personal choice.
I would suggest, when ready, invest in some adjustable shocks. QA1s are popular
PS. Your are asking about a 4th gen if it's a 2013. Ask the mods to move to the 4th gen section you might get more responses
