Tires and gear ratio
da_garr99
British Columbia
Hi everybody, could not find an exact answer so here I am and its alot sorry in advance. I have a 2009 dodge ram 1500 5.7 slt and am in need of new tires. Highway and city driving 50/50%, occasionally offroad, might tow a camper trailer in a few years. Stock tires are 275/60/20 (33"), currently running 33×12.5 20. I want to either run 285/75/17 (33.8") or a 285/70/17 (32.7") falken wildpeak at3. I do not know my gear ratio (will not have access to my truck for another few days so i cant check unfortunately). My questions are, what size should I run? Does anybody reccomend a different size instead of those? And if i go bigger how much stress will the 285/75/17 put on my driveline? I do not want to regear so have been leaning towards the 285/70/17 but I have no clue. I would like to have this truck for many years and I have been babying it alot. First time ever buying tires so I'm overthinking alot. Thank you for the help
Dean2
Near Edmonton
Welcome fellow Canadian.
The diameter differences you are talking about are completely irrelevant with respect to gearing. From 33" to 33.8" is 2.4% increase in diameter. You will get slight differences in your speedo readout but even that is not real significant, and can be adjusted to read correctly.
DIAMETER, ROLLOUT (CIRCUMFERENCE) AND REVOLUTIONS PER MILE CHART
Below is a chart to assist in vehicle drive-train calculations.
DiameterRolloutRevs/Mile*
17.555.01222
1856.51186
18.558.11152
1959.71120
19.561.31090
2062.81061
2269.1960
22.570.7938
2372.3917
23.573.8896
2475.4877
24.577.0858
2578.5840
25.580.1823
2681.7807
26.583.3791
2784.8776
27.586.4761
2888.0747
28.589.5733
2991.1720
29.592.7708
3094.2695
30.595.8684
3197.4672
31.599.0661
32100.5651
32.5102.1640
33103.7630
33.5105.2621
34106.8611
34.5108.4602
35110.0593
35.5111.5585
36113.1576
36.5114.7568
37116.2560
37.5117.8553
38119.4545
38.5121.0538
39.5124.1524
40125.7517
45.5142.9453
46144.5448
53166.5388
53.5168.1384
54169.6381
Jeepwalker
WI
2012 Reg Cab, 4x4
Furthermore, there can be slight variation of *actual* measured tire OD size between mfgrs of the same size tire. Also, the difference in diameter of any tires you buy could be ~16mm (5/8") from brand new OD to the "time to replace" OD. So, good question, but the differences you're talking about are acomadated by the mfgr.
Interesting Note: For guys who DO consider quite a bit larger or smaller tires, the truck's computer can be easily re-programmed to accomodate tires of greater different OD size. There's a drop-down selection in the menu of many scanners when you link to the truck's computer and a long list of tire sizes which can be selected from. Depending on the tire size, it modifies the truck's fuel mapping, shifting programming and other parameters. Just an interesting side note. But in your case you shouldn't need to do anything.
Let us know how you like the Wild Peaks :favorites13:
D
da_garr99
British Columbia
17.555.01222
1856.51186
18.558.11152
1959.71120
19.561.31090
2062.81061
2269.1960
22.570.7938
2372.3917
23.573.8896
2475.4877
24.577.0858
2578.5840
25.580.1823
2681.7807
26.583.3791
2784.8776
27.586.4761
2888.0747
28.589.5733
2991.1720
29.592.7708
3094.2695
30.595.8684
3197.4672
31.599.0661
32100.5651
32.5102.1640
33103.7630
33.5105.2621
34106.8611
34.5108.4602
35110.0593
35.5111.5585
36113.1576
36.5114.7568
37116.2560
37.5117.8553
38119.4545
38.5121.0538
39.5124.1524
40125.7517
45.5142.9453
46144.5448
53166.5388
53.5168.1384
54169.6381
thanks for the help and nice to see a fellow Canadian! picked up the 285/75/17 today, hopefully getting them mounted this week or next. Currently rim shopping
D
da_garr99
British Columbia
Picked up the 285/75/17 today, will let you know in a few months how I like the wild peaks
Dean2
Near Edmonton
You may already know this but when rim shopping try to keep the offset on the new ones the same as your OEM rims. Also, going to 17s you want to test fit them before you buy them to make sure they clear the brake calipers properly and that there is room for balance weights.
D
da_garr99
British Columbia
Very smart, I plan on going with a -12 offset. What happens when you deviate from stock offset ?
Dean2
Near Edmonton
The problem comes in when guys move the face of the mounting plate closer to the back of the rim. This increases negative offset. If the mounting plate was dead centre tou would have zero offset. As you move the mounting plate out board you get positve offset. Guys increase negative offset so wider tires clear at full lock and because they think it looks good This pushes the tire and rim further outboard of the wheel and wheel well. This means your wheel well may no longer cover the tire and it also puts a whole wack more pressure on bearings and front ends as well as rear bearings. The more leverage you apply the worse it gets. What was your factory offset. As long as the new negative offset is not greater you should have no issues.
D
da_garr99
British Columbia
The problem comes in when guys move the face of the mounting plate closer to the back of the rim. Guys do this so wider tires clear at full lock and because they think it looks good This pushes the tire and rim further outboard of the wheel and wheel well. This means your wheel well may no longer cover the tire and it also puts a whole wack more pressure on bearings and front ends as well as rear bearings. The more leverage you apply the worse it gets. What was your factory offset.
I do now know my factory offset, can check tomorrow night when I get home
Dean2
Near Edmonton
Minus 12 is 12 milimeters so about a half an inch. The stock offset was usually from positive 20 to 25 depending on the exact wheel package. That means you are moving the tires outboard about an inch and a half, which is quite a bit.
CanRebel
Toronto
Was bored, so I checked. Says 17-21. some list it as 19. As @Dean2 mentioned above.
You should check for yourself and make sure you really want -12 , as he said above, that is a big change.
D
da_garr99
British Columbia
I'm definitely not going with a -12 offset. Would you reccomend a 0 or a +1 ? My wife bought me bushwacker fender flares and she has made it her mission to get them on lol. So I want to try and have the tires flush or a little inward, but don't want it to look super tucked in. My rims say 20×8j +19.05 on the back of them. Ideally I would like to go with a 9 inch wide rim but are a bit concerned with my suspension and uca. Thanks for the help
D
da_garr99
British Columbia
My rims are 20×8j 19.05. What would you reccomend for offset ? Want to go with 9 inch wide rim (don't know pros and cons to a wider rim) but concerned about uca and suspension
Dean2
Near Edmonton
Going to an inch wider rim means it is 1/2" outside and in. Since you are at a -20 offset now on the stock rims a -8 would compensate fully for the extra 1/2". Based on your OEM stock tires being 275s, new tires 285, you are gaining less than a 1/2" in width, so the new tire is 11.2" versus stock at 10.8 and your existing tires at 12.5". So in effect you are going to a new tire that is 1.3" narrower than your existing tires. Personally, I would stay with the 8" or 8.5" rim and keep the stock offset.
Dean2
Near Edmonton
One final work of advice, a good tire or tire and rim shop should easily be able to get you into the right 17" rim using a factory or real close to factory offset of -16 to -20. Formula for tire with to Rim width is rim width x 1.33, so in this case ideal would be an 8.5" rim for the 285/75/17 tires, but 8" works too. Good thing about 17" tires is there is a way better selection and they are a whole bunch cheaper than 20 inch rubber. The biggest trick is to make sure nothing rubs and the rims clear your calipers, which on a 2009 they should as they came stock with 17s on some models.
Let us know what you end up with.
Jeepwalker
WI
2012 Reg Cab, 4x4
OP, Unless you have a particular style of aftermarket wheel in mind. But if not, are you open to a *stock* Ram 17" wheel? You might be able to find a good used set of take-off's on your local "used" listings (Facebook Marketplace/Craigslist ...or whatever is popular in your area). Perhaps a set that was removed years ago an owner now wants to get rid of. The benefit would be a good set of wheels for a lot less than aftermarkets. And around here (salt) aftermarket wheels don't typically hold up as well as OEM.
That's what I've done in the past on a few vehicles, when I wanted to get a better set of corrosion-free wheels. The previous owner of my Ram must have done that too by the looks of the build sheet.
Just a thought..
D
da_garr99
British Columbia
Going to an inch wider rim means it is 1/2" outside and in. Since you are at a -20 offset now on the stock rims a -8 would compensate fully for the extra 1/2". Based on your OEM stock tires being 275s, new tires 285, you are gaining less than a 1/2" in width, so the new tire is 11.2" versus stock at 10.8 and your existing tires at 12.5". So in effect you are going to a new tire that is 1.3" narrower than your existing tires. Personally, I would stay with the 8" rim and keep the stock offset.
That makes alot of sense, thank you for the help and very valuable knowledge.
D
da_garr99
British Columbia
Just a thought..
I was looking at some fuel rims. Unfortunately where I am everybody thinks their beat up rims are worth 1k which is really stupid
D
da_garr99
British Columbia
Will definitely remember the rim formula. I would have loved to get some 2nd hand rims but people in BC price their rims stupid high and alot of tire shops out here are sold out on so much
