Towing tuners
jgmartinez274
Vacaville, CA
5.9 Cummins
Advise on a Towing tuner for my 2004.5 Cummins. Thank you all in advance for your help.
J
jgmartinez274
Vacaville, CA
5.9 Cummins
I upgraded my transmission recently and it feels like am not getting good throttle response. I don’t have enough $$$ to upgrade the stock turbo just yet and I was told I could install a tuner.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Work with a custom tuner that will write a tune to also address trans tuning to keep line pressures where they need to be to help the trans live longer. Don't just throw power tunes at it. First though you should verify the engine is up to par and you don't have a boost leak or bad injector. Tuning won't fix that.
Travelin Ram
I’ve seen a bunch of people go down this rabbit hole.
“Upgraded” transmission underperforms because they tamper with the torque converter and shift parameters. Which were originally matched to the engine.
What you’re feeling is a LESS efficient transmission.
I have been down that road. If you uprate the engine stay mild, more power just exposes more weak links to spend on.
chri5k
USA
Diesel
What upgrades were done to the transmission?
