Mister Luck
cassis tutissima virtus
- Aug 25, 2020
- 1,651
- 590
- Location
- WEST COAST
- 2016/2017
- 5.7 V8
If your tires have over 16 ounces of weight attached for any one rim that is a lot of zinc at RPMMy sound proofing definitely has metal in it. As far as the frequency the guys set I don’t know.
I did pull out the RF hub, away from the sound proofing while being connected and no changes.
I’m going to call the tire shop to see if the hub is working from the tpms side of things. I know it’s working as far as the radio and other functions go. I unplugged it and the truck was dead and not even turnover.
The wheel weights are the metal rectangles that stick to the rim. Double sided tape??
I’ve had the same tires since I bought when the TPMS worked so I would say it’s not the tires.
Thanks for all help.
The other option could be an aftermarket radio or audio visual console that’s interfering.
You don't have other remotes or a cellphone that could be doing this ?
Maybe a parts store has a reader that can tell you what frequency your current TPMS are ?
There is a bluetooth reader fir TPMS in the Apple App Store supposedly it is able to read capture the serial numbers from the TPMS sensors haven't tried it myself but I plan-to when it stops raining here..
