Tpms
silverkitten
Oregon
Forgive me if this is the wrong place to post. 2013 1500 express I had 4 new TPMS installed 4 new tires, now occasionally the light comes on, shows it's not finding the r/r sensor. I took it back to the shop. Their scanner showed r/f sensor. They replaced both and it still does it. Any advice would be very appreciated.
BossHogg
Oakland Township, Michigan
6.7L Cummins
Try rotating your tires and see if the issue follows the tire. Each wheel opening has its own antenna for sensing the TPMS sensor.
quasarn01
Dandridge, TN
I had the same problem until I relocarted my TPMS module from the front driver's corner to right behind the front left fender shroud... Watch this video and see if it might be of help...
Relocating the TPMS Module
