- Feb 13, 2019
- 2,712
- 7,603
- Location
- South Jersey
- 2022
- Hemi 5.7
Those LED awning lights are so bright. I see very few people in the campgrounds using them. Most use a different light.
yeah, i like our awning lites for when we have gatherings at nite but would like something dim for a alternativeThose LED awning lights are so bright. I see very few people in the campgrounds using them. Most use a different light.
I have garage door opener light, but it is LED & does not allow the opener to function, unless i am right at the door, so i unscrewed that light
They have LED lights specifically for garage door openers.
https://www.geniecompany.com/garage-door-openers/accessories/led-light-bulb.aspx
Here's something else I came across. I've used it twice and both times it worked great. It's a flexible fitting that goes into the sewer line. This thing has been awesome. When it's seated in it doesn't fall out. Both times I used it, when I tried to pull it out the end of the sewer line came with it. It doesn't come out as easy as the videos show. Maybe I have it seated too deep but I'd rather fight with it to get it out when I'm done than have it fall out in the middle of dumping. It's so much nicer than a regular elbow.
As you can see the best part is that it fits all different angles. Most sites I stay at have angled sewer dumps. The pic is our latest camp site. It really worked well there.
It's called the rhino 3 in 1 flexible sewer hose.
https://www.amazon.com/dp/B07FJFZPHL/ref=cm_sw_r_cp_apa_glt_fabc_15MTTHHXWHRP317KXKX0
https://www.walmart.com/ip/Camco-39...l-with-RhinoExtreme-Hose-and-Handle/857474883
I really wish they were plumbed together. The front one is the kitchen gray and the rear is bathroom. My last trailer was the opposite. Front bath and rear kitchen but not plumbed together either.Your trailer has two sewer outlets? Both of my gray tanks and my black tank use the one.
Both of my tanks go to a single outlet also....but I have seen this more and more on newer rigs...I guess due to the layouts folks want these days. Probably necessitates the need for separate black and gray tank connections.
Cool flexible adapter though LR!
Thanks.
My gray tank and my black tank in the bathroom does have one connection like a typical trailer. I have a second separate gray tank just for my kitchen. I may not have been clear.
