Transmission question
olove
Dallas
I have a 2007 dodge ram 1500 quad 4.7L flex with 278K miles. I was driving on the highway and when I got off and turned the corner, the transmission seemed to disengage and the RPM's rev to like 7000. I trans would not shift into any gears and when I do shift from park, the RPM's just go high, no gears work. When I shift from reverse to park, I can hear a grinding noise. Checked for codes but nothing. I had the car towed to my house and I changed the fluid and filters but no change. Everything looked intact (filters) as it should when I changed the fluids. Any assistance would be greatly appreciated. Thanks
ppine
Forester
Nevada
6.7 liter diesel
Time to rebuild your trans.
jws123
nj
at 278k that baby is way past due if its orig just throw a good lower mileage trans in if you like the truck.
