Transmission
Flaplaca
Ontario NY
6.7 Deisel
My 2018 with 50k miles is clunking on the downshift. Between 4/5 gears and 2/1 gears. Sometime hard, others a soft clunk. Anyone have this issue?
bigdodge
I had that issue with my 66rfe so I changed teams fluid work redline trans fluid and it's never done it since
Rick155
HEMI 5.7
I have a 2017 1500 just out of warranty by miles not time (69,000 miles, still months before the 6 years). Transmission would clunk when cold driving 25mph. Took to dealer twice and they said they could not produce problem. One morning made the clunk and would not shift to 2nd gear. Took it to the dealer and they told that the transmission was trashed and not servicable. Long story short, $9500.00 for a reman or $5000 for a used one with 50,000 miles and no warranty. Called Customer Service and they were very Snotty with me and said there was nothing I could do. Very disappointed with the whole thing and especially Customer Service. They made me feel sorry that I bought a RAM. Going with a Ford this year!
F
Flaplaca
Ontario NY
6.7 Deisel
this has the 68rfe.
We actually took it in for service. 2 things fixed the problem.
Low transmission oil - down 2 quarts and not leaking anywhere, i was perplexed over this, and service pack update. I havent had the issue since.
Gr8bawana
6.7 CTD
this has the 68rfe.
These trucks do have a dipstick so you can check the fluid level you know. :doh2:
06 Dodge
Forest Grove, Oregon
6.7L CTD
I'm sorry to hear your trans went to crap, but you are 9,000 miles out of warranty so that is why they said no fixing it under warranty, also do you really think/believe Ford does not have its own set of problems with its transmissions, think again, same with GMC, they all are having problems with different things breaking or not working properly including I'm sad to say Toyota that I'm personally finding out about...
Administrator
@Rick155 both Ford and GM have pending litigation over their 10 spd transmission, it's the same transmission that was co-developed between them.
Failures with the ZF 8HP transmission are actually on the rare side and many different manufacturers use this same transmission design.
Fuel35 67
Hanford
I would think since the trans had a problem during the warranty period, Ram would offer something.
nlambert182
Huntsville, AL
Brother, good luck on that Ford! I can promise you 100% that you'll have a lot more problems with your 10-spd in the Ford than this Ram. If you are upset that Ram customer service won't help you on a trans out of warranty then wait until you deal with Ford with a trans IN warranty.
They allowed our Expedition to sit on a lift from June 2022 to January 1, 2023 with the transmission on a bench. Not only did they redesign the components while it sat on the bench TWICE, once installed the transmission only made it 88 miles before it puked it's guts again. And guess what? Some of the newly designed components were STILL wrong and it had to go back under the knife again. Best part during all of this? Ford wouldn't front the rental expenses but promised in writing to reimburse us. Once we did get it back prior to it puking the last time we submitted our invoices from the rental company. Ford ended up only reimbursing us for half of the money and we ate $2k in rental car fees. The Ford CSR's advice.... dump the Ford and don't buy a Mustang, Ranger, Expedition, or F150 until they figure out how to solve the transmission problem.
We sold it to the dealership and wrote a $14k check to pay it off so that we could walk away from it. It would have been cheaper to replace the transmission in a Ram than what we went through.
