TRX Wheels
tacky1
California
2021 Rebel
Guys, Quick question, I can get my hands on a new set of TRX wheels and tires, the standard rims, not the beadlocks.
Will they fit my Rebel or do I need to do some mods, like a lift or spacers etc, Thanks.
PaleFlyer
Charlotte NC
When you say the non-beadlock rims, do you mean the ones that look the same as the 4th gen rebel rims? Looking at pics online, the TRX rims either look to be the beadlocks, or the "all black" equivalent to the rims my '18 Rebel has. First pic looks like my rims, second is what I am seeing as the primary "beadlock" design.
olyelr
Kewadin MI
They are completely different wheels than the rebel ones, although they do resemble each other. They both have basically the same offset (19/19.05), but the trx wheels are 9” wide while the rebels are 8”.
Racing Woody
Dublin, OH
Wheels will fit. Tires will be very tight in the front, and possible it the UCA. Will need at least a 1/2" spacer if I remember correctly from other threads. You will also rub on the mud flap/wheel liner on the front wheels, I had to remove my small mud flap, cut the plastic liner and BFH the weld flat and i still get some rub at full lock even with a lift. I am running 1.5" spacers and a 2" lift.
