Turn signal relay location
kapster411
Ohio
6.7 cummins
I have a 2019 Ram 3500 6.7 cummins. I had a load of 1600 lbs in the bed and as soon as it was loaded, the rear left turn signal was out. The bulb is good and I have power to it. Thinking I would go after the relay. I dont know if the load had anything to do with it but it was fine until then. Does anyone know where the turn signal relay is located?
mtnrider
Georgia
There is no relay, it's all controlled by the BCM...
Administrator
If you have power to socket, and the bulb test good then it's probably the socket not making contact with the bulb. Use a meter or test light to test between the terminals inside the socket.
