Unstable Towing with our 1500
OC455
Central NY
To the OP, @rickshein what did you figure out was going on?
Inquiring minds want to know.
CalDad14
Calgary, Alberta, Canada
2017 Ram 1500 Crew Cab, 4x4, 6-speed, short bed, 392gears
My opinion, it’s to big and heavy to be pulled behind a 1/2 ton truck.
Others have different opinions about towing.
The frame, suspension and brakes aren’t built for that much additional load on the truck.
My first concern is brakes in any towing setup.
If the brakes were to fail on the trailer for any reason. Can the truck stop going down a 20 degree grade doing 60 MPH?
If you’ve ever worked on a 3/4 or 1 ton truck compared to a 1/2 ton there is a HUGE difference in brakes and suspension.
Weight distribution hitches help but it still doesn’t change the amount of weight behind the truck.
I thought the 1/2 ton Rams were only rated at 500lbs tongue weight?
I’ve watched way to many YouTube videos of towing mistakes to give an unbiased opinion..
I would never tow anything that weighed more then 3K behind a 1/2 ton pickup.
Just because they say it can do it doesn’t mean you should.
Good luck, I hope you get it sorted out.
The recommended tongue weight for a conventional hitch is 10 percent of the gross trailer weight. The maximum tongue weight for Class IV receiver hitch is limited to 1100 lb.
josephus
Charlotte NC
5.7 E torque Hemi
I have a 2020 LongHorn and having the same problem towing a 7000# Jayco 30' camper. I was pulling it with a 2017 Chevy High Country and it is the best towing camper I have ever had. Someone stole my truck so a friend talked me into buying a Ram since I couldn't find a new Hi Country. I'm using the same Reece WDH but now it's pretty scary towing. 1st trip the trailer was swaying really bad. I called the camper dealer and he told me to turn off the anti skid , he had gotten a bulletin saying the anti skid would work against the anti skid on the trailer. I did it on my return trip from the beach and that cured the tail wagging but now I have another problem with the front feeling light and it's hard to handle at speeds of 68 to 70. 72 was much better. I just went back to the camper dealer and he re-adjusted the hitch but he noticed how soft the suspension was in the rear by just pushing down a little bit on the hitch. He suggested air suspension. The truck is just slightly down with nothing in the truck bed but the camper is level. I believe having rear coil spring suspension is the problem because they are too soft. Now I'm thinking about another Chevy since they have leaf rears. I love this truck but this may be the only option. I don't have much weight in the front of the camper.
Administrator
You really need to check the adjustment of the WDH, find a CAT scale and weight the truck and trailer loaded as if your going camping, then drop the trailer and weigh just the truck. Without checking actual weights your camper dealer is just guessing on how to adjust the WDH.
Eric Troup
Orlando, FL
Our travel trailer tail is wagging our RAM 1500 dog. Our configuration:
2021 RAM 1500 Limited (V8 Hemi w/air suspension)
Weights per the door frame sticker are:
GVWR: 7100 lb
GAWR front: 3900 lb
GAWR rear: 4100 lb
Max payload: 1359 lb
Max towing: 8159 lb
Gulf Stream Conquest Lite 238RK (length 27' 11", spec dry wt 4815, hitch wt 640)
Reese hitch 49911 - max gross wt/tongue wt: 6000/600
Tires on the TT (ST205/75R14) have been upgraded to Goodyear Endurance tires.
We had ourselves weighed on the first trip, and the weights were:
Front truck axle-3320, Rear truck axle-3960, Trailer axle(s)-4880. Actual hitch weight unknown.
The weight of the trailer is well within the capability of the RAM 1500 and the rating of the hitch appears to be correct (hitch weight is only slightly over). The hitch was installed and adjusted by our dealer. The trailer was not heavily loaded, and not in any strange way that would have changed the tongue weight much. However, at speeds approaching 55 mph, it starts to approach a white knuckle drive. It seems to sway and is overly sensitive/bouncy to uneven roads. The Reese hitch is supposed to have integrated sway control, but it doesn't feel like it.
After posting this same question to a Facebook Newbie RV group, the leading theory is that the air suspension, once its reengaged (jack mode disabled per the user manual) is conflicting with the weight distribution setup ().
For those of you out there with a 1500 Limited and a similar size travel trailer, what is your experience? Do you stick with the user manual setup? Do you drive with jack mode left on?
I have pulled a 2019 Keystone Cougar 29bhs with a 2020 Ram EcoDiesel Limited with the four corner Automatic Leveling Air Suspension. The only thing changed on the truck from stock was to upgrade to Load Range E tires.
I used a Curt TruTrack Weight Distribution System w/ Sway Control Trunnion - 10,000 lbs GTW, 1,000 lbs Item # C17500. This rig is heavier than the one you describe. Although the Cougar 29bhs weight and size are at the upper limit for the 1500 EcoDiesel, properly setup the rig does not sway at speed. Nonetheless, it is too heavy for the 1500 and a Ram 2500 is a more appropriate TV.
I also pull a 2021 Airstream International 27FB using the same Curt WDH. The Ram 1500 EcoDiesel pulls this 6000 lbs trailer easily without any sway at speed and is completely relaxing to drive. The EcoDiesel Air Suspension does an excellent job keeping everything level but it is important to turn off the Auto Leveling feature when setting up the WDH. If you do not, the auto leveling system will compensate for the hitch weight and level the truck before you can measure sag and setup the WDH to compensate. However, the WDH does not have to completely level the truck as the Air Suspension will do much of that work anyway. I use the CURT WDH primarily for effective sway control.
I see two possible problems causing your sway:
1. Actual hitch weight is too low. You must have 10-15% of the actual loaded trailer weight on the hitch. Two much weight at the rear of the trailer can cause sway to amplify and become dangerous.
2. Reese Hitch 49911 has minimum sway control - primarily via friction of the flat bars sliding over metal taps. Look at CURT tru-track. In addition to the friction bars, it has "spring-loaded ball bearings in the head that rest in detents, applying constant pressure to help trailer stay centered".
For your lighter trailer you could consider the Curt TruTrack Weight Distribution System w/ Sway Control Trunnion - 8,000 lbs GTW, 800 lbs TW Item # C17499
On a CAT Scale suggest you:
1. Weight your truck empty (Driver and full tank of Fuel). Record Steering Axle and Drive Axle Weights. Compare total to GVWR. The difference is your actual payload. Compare to door sticker. You probably have less actual pay load than the door sticker says.
2. Weigh your truck fully loaded with all people and cargo but no trailer. Leave the WDH hitch on the truck. Record Steering Axle and Drive Axle weights. Compare total to GVWR. The difference is your remaining Payload available for hitch weight.
3. Weigh your truck fully loaded with trailer in tow. Record Steering Axle, Drive Axle and Trailer Axle weights. Compare total weight of Steering + Drive Axle. The difference between total in Step 3 and total in step 2 is your actual hitch weight.
Good Luck!
Cactusmonkey
Central Washington
Rickshein we have the exact same set up you do. 2021 Limited Hemi with air ride. We pull a 26.8 ft trailer that weighs 7700 pounds loaded. Last weekend took it to the Snake river to a park that does not have water. We filled the 80 gallon fresh water tank at the house and drove 100 miles. The truck was perfect in fact on a long straight I pulled at 65 mph which is fast for me. I like to pull between 55 and 62, depending on traffic. The only difference I see between your set up and ours is the WDH, we use the Equalizer. The truck has Goodrich tires and the trailer has Goodyear Endurance. We have pulled this trailer and others with 1/2 ton Fords and now the Ram. I feel that I have plenty of truck with this setup.
Firebird
2019 Ram 2500
I have the Equalizer WDH hitch also, it does an excellent job!
redraml
Colorado
This has been a very helpful thread as I am new to towing. I have a 2019 Laramie 3.92 axle with 5.7 eTorque, sunroof and skid plates. When I put my VIN into the RAM site, I got 1340 lbs payload and 11200 lbs tow. But when I weighed my truck today with my wife and 2 small dogs (about 350 lbs total) plus full tank of gas, I got 5940 lbs (3500 front, 2440 rear). So my actual payload must be around 1500 lbs! Has anyone found similar differences?
I am shopping for a TT in the 5000 lb to 6200 lb (dry) range, with a maximum hitch weight of 1000 lbs (around 12% of TT weight). This seems a good hitch weight to get my rear axle weight close to the front axle weight. I prefer not to use a WDH since I plan to go off road - is that reasonable?
Red Deer Ram
Red Deer, AB
5E26A43C-AC9D-4EE7-BB36-97E4A6E9DF2D.jpegMy trailer is heavier than yours and I tow comfortably. I have a Reese Straightline 1200 WDH which has a cam arm system that really helps with trailer sway. Michelin Defender tires on the truck and for additional stability a set of Airlift 1000 airbags that are inflated separately. I don’t use the bags for height compensation. They are typically inflated to 15 psi. Tires make a difference. This year I swapped out the trailer rubber to Goodyear Endurance, but I honestly don’t notice a difference. Peace of mind mostly.
ramffml
ramforum
Your door sticker is "king". Whatever your door sticker says, is what you have for payload. Definitely use your door sticker over the website with VIN.
Ram says you need a WDH past 5000 pounds, and I can't imagine not using one either. I don't know how you're going to haul 6000 pounds off road anyway unless you buy a special offroad trailer. Safety first, use a WDH to get your offroad site then disconnect bars and with your speed down you should be fine.
Farmer Fran
Earth
2020 Limited Loaded - Sold
no, over 5K you need a WDH
riden2low
Otis Oregon
I pull about the same size TT. I took the street tires off and had 10 ply mounted.
runamuck
dfw
6.7 dsl
redrami I have similar '19 ram 1500 laramie. cargo cap says 1324#. with just me in the truck and 1/2 tank of gas CAT wt 5960# so I only have 1140# left for wife and gear and trailer. found out my 6000# trailer has actual tongue wt. of 560# when I bought a scale and weighed it. It tows great and I dont notice any sway but I now plan to stow a few more things toward the front of the trailer. I generally set cruise for 68-69 and get 8.5-10 mpg. I have airbags in the rear and run 20# when towing and also add some air to the rear tires for extra stiffness. I had a '17 gmc sierra 4x4 ccsb before getting this ram and it struggled to pull this trailer..mostly because of the 6 speed tranny. I would not go back to a gm 1500 unless it was the 1500 with the new dsl. people say they tow great, have lots of payload and get 14 mpg or more towing.
bodasn
midwest
the only time i have been whip by the trailer is when i had to much weight behind the trailer axles
Red Deer Ram
Red Deer, AB
GVWR: 7100 lb
GAWR front: 3900 lb
GAWR rear: 4100 lb
Max towing: 8159 lb
So my setup is on a 4th gen. I can’t imagine there’s that much difference. 31’ Rockwood 5900# Dry 814# hitch weight. 2012 CC 4WD Hemi. We tow very nicely. My truck has a set of 20”Michelin Defender LTX tires, Airlift 1000 airbags. I run about 15 lbs in the bags, they are inflated independently and are not used to level the truck. They do add some cornering stability. Good year Endurance tires on the TT although they were installed this year. Didn’t notice much improvement in the towing performance as the trailer towed pretty nice before. The WDH is a Reese Straightline 1200. I feel this is the key to our stability, along with the Michelins on the truck. We have towed our trailer through every type of terrain and always been comfortable. Not sure if this helps. It works for us and has since we bought the truck in 2012.
JRob79
Portland, OR
I cannot say compared to a Ram 1500 but my cousin has problems with his weight distribution hitch and his active air suspension on his MDX.
S.Dodge
I've never had a worse truck for towing than my 4th gen 1500 outdoorsman, crewcab LWB 4x4 with 3.92 gears. To light. Yes they can be set up a little better with special hitches and balancing acts etc but in my opinion for towning get a 2500 or 3500. They have no payload capability whatsoever. My last TT was a 28 foot that weighed about 7900 dry and a tongue weight of 900lbs with battery and propane. Only towed it a short distance and it was awful. So legally I couldn't take the family or my 4 wheeler. With my 2500 I can do it all and not know it's back there and do it much safer. Now I have a 12,000 lb 5th wheel that I can't even consider using the 1500 to pull. I use the 1500 as a car basically and use the box when I can. Rides great, reliable but no good for towing. Leave that to the HD trucks. People say it can be done and they do it and I belive them to a point, but I've done it with 1500, 2500 and 3500. The ram 1500 is just to light, especially on the highway.
KeithP
Hemi 5.7 VVT
I’ve worked for U-Haul for 15 years. In my time w/U-Haul I have dealt with countless complaints about trailers swaying. Every time, without fail, it was due to improper weight distribution. When you load the pillows in the front of the trailer and the refrigerator in the back, trailer life is going to miserable.
