Upper Ball Joint Nut Size
Paul M
Colorado
2010 2500 HD Laramie
6.7L L6 turbodiesel OHV 24-valve
Anyone know the proper size of the Upper Ball Joint retaining nut? Can't seem to locate it online and mine was [oddly] missing.
Was rotating tires and discovered the nut missing, hence a little rattle while driving over uneven ground or pavement...maybe when the ball joints were replaced as I find it hard to believe it loosened and fell off. Tried a bunch of on-hand hex nuts, none fit the thread (assuming 18mm w/ 2mm pitch??). Then tried my Kobalt portable table saw arbor nut...fit perfect. But I want to replace it (and the table saw size is not known either). Thx.
danielmid
Southeast WI
2015 Sport 4x4
I think it's this one here, but you could always take the nut in to Ace or Home Depot and check bolts until you find the right size. I'd opt for the OEM one myself.
Tulecreeper
Sthrn AZ
Wrong forum. This is for 2019 and newer. (I beat ya, Craig) :cool:
P
Paul M
Colorado
Geez, sorry, missed that. But will try the recommended link. Much appreciated.
P
Paul M
Colorado
Ordered...
gtomike60
Milford,Mass
5.7L HEMI
There should be cotter pins installed on the castle nuts on all the ball joints to prevent the nuts from backing out
P
Paul M
Colorado
Exactly, which may have gotten missed on this one whereas the passenger side is complete.
