V10 swap
2000.2500.ram
12v cummins
Ok guys. I'm doing a 12v Cummins swap into my 96 v10 3500 4wd. Its a 5 speed also.
The 12v I have is actually a ve pump but figured u guys could help more. I've done researched a lot of things. But still having a couple of little bumps. And trying to get it all sorted out because picking up the motor this week and gna start rebuilding it.
1) the tach is the only thing I'm having bugs with
I'm using stock cluster. May change out but cants find a parts truck. But basically I'm gna take the sensors off the v10 and put them on the 12v. So oil press water temp speedo and everything will still work. Just can't figure out the rpms. Thanks
Sent from my HTC One using Tapatalk
cbassrex
