Warlock wheels and tires
KingEnder13
Portland, OR
I'm looking to install Bilstein 5100 B8s set to 2.1 to level my warlock and achieve the 3" overall lift.
I am starting to game plan for wheels and tires after the level and am curious what will fit without any rub or break caliper issues. I want to stick with the 20" wheels, as well at 33"s tires, but would like something wider for a better stance. I'm new to wheels and tires so am curious what I would be able to fit properly without any issues or rubbing. I was looking at either 10" or 12" wide wheels or/also something with an offset. Any thoughts or inputs? Was eying Toyo Open Country A/T IIIs, possibly at 33x12.50R20LT
hunterdan
SE PA
2019 classic
Swapping to the Bilstein set at 2.1" isn't going to net you 3" of lift. You'll only be about an inch taller than you are now. As for the wheels, can't help much there.
GRKN
Yep with bilsteins you are replacing the factory strut which is the means of the 1” lift. So you will actually net about 1” less then whatever you set the bilsteins at. I’d be setting them at 2.8 and get a good set of angle correcting UCAs like JBA.
KingEnder13
KingEnder13
Portland, OR
Yeah I already have all the correct parts sorted out with one of the preferred members. I may have misspoke with the lift, but the goal is to level it and it was my understanding that the rear has 3 inchs where the front has just the one.
Administrator
currently have a 2020 warlock with OE wheels/tires (275/60/20)
A similar size tire for a 17" rim would be 285/70/17, close enough the speedometer won't need adjustment.
RamDiver
Marlborough, Ontario, Canada
figured i would post here instead are starting a new thread.
looking to size down my wheel to 17'' for a winter tire. will these fit with little issue (https://www.oewheelsllc.com/DG55-17080-black-painted-inlay-polished-wheel-fit-Ram-1500) ?
and what size tire recs?
If you want more control in a winter tire, I'd use an online tool like crash68 presented but go much narrower.
I use 245/75/17s for deep snow in winter up here and they're fantastic.
It depends on what conditions you have but narrower is always better for winter fun and safe control of your truck.
