What Did You Do To Your RAM Today?
Ram Sport Man
San Diego
Then - 2002 , Now - 2015
Then - 5.9 , Now - Hemi 5.7
Changed out headlight bulbs with Hikari LED conversion kit and Hikari anti-flickering decoder. Look brighter, but I'll see the truth once it gets dark here tonight. Working on uploading pics.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
been away from mopar for a while, working on the wifes Chevelle. but a deal I couldn't pass up came up. browsing craigslist is the devil... anyway, bought my 72 D100 a new engine, 5.9 magnum with 99,000 miles. it was attached to an a518 as well as the rest of a 2002 Ram 2500. gotta pull the motor next weekend and tear into it. doesn' t need it but I like a 'clean slate'. would like to keep the factory EFI but will be putting on some RT heads and cams so will likely be going with Fitech.
crazzywolfie
crazzywolfie
under the truck
if your good with wiring you may be better off making the 2002 harness work. the computer is tuneable for any parts you can put on plus the MPFI will likely work just as good if not better than the Fitech. plus i doubt that 46RE will work without the pcm unless it is a 46RH that is usually only found in the 90-95 trucks/vans. you can order a hotwire harness for about $1k but makes it simpler for you.
reek
Sacramento
I'll be rebuilding one of my 46rh for this application, no 46 RE for me. Just finishing the wifes TH350 rebuild so that's next on the to do list.
I really do want to keep the MPFI but my understanding is that with cams/heads the good old handheld tuners won't do. that is, I'll have to trailer the truck over for a dyno tune. Is my assumption correct? I have little computer knowledge but can tune the crap out of a carburetor so any info appreciated.
McBroom
Denison Tx
Hemi 6.4L
The Blue Mule
crazzywolfie
crazzywolfie
under the truck
changed out the hall effects sensor on the 89. seems like it is running a bit better overall along with the inline fuel pump. somethings still may not be 100% right but still seems better than it was.
RonJon '06
Southern Minnesota
Replaced the high pressure power steering hose, the hose developed a pretty big leak last weekend.
Anonymous007
KY
Tinted windows a couple days ago
crazzywolfie
crazzywolfie
under the truck
you want to do the one on my 89 also lol. mine has had a slow leak for a couple years now. now the big new leak is the pitman arm seal. service manual makes it sound like a easy repair but i guess we will see lol.
RonJon '06
Southern Minnesota
^^ they both look good
Yeah, I'll be right over lol. I've got a couple small leaks on the truck that I'm putting off as well but this one was spraying everything on the drivers side of the engine bay
:insane:
crazzywolfie
crazzywolfie
under the truck
lol. i am guessing you also have a rear main seal leak also lol. that is a normal also. at least these are pretty easy to do that line on. the magnum engines are worse to try replacing the line on. i think i had to remove the entire power steering pump just to get the line out of it. it is a lot easier to get at the lines on the non magnum engines.
nice trucks. never been a fan of them newer style rims
PaPitt
Stephenville TEXAS 76401
5.9L
SO due to the Covid issues every where ...One of our 16 but only about a month from 17 year old grand Sons .. He's been able to almost spend the entire summer with Mimi & i . Now he's from the city && we're definitely country folks .. Mimi is retired due to Covid .
& She's almost 71 . i'LL BE 71 IN a few days. But I'm still working . 45hr in town & Then about 30 a week on my 140ac farm.
... But my 1988 Hay truck .. SO TRoy my grand son ..It's time for him to start grinding & get this Western Hauler bed ready to paint. Well Black Bed Liner it . SO TRoy spent about 6 hours grinding on it Friday . & Then about another 6 on Saturday ..
But we got several parts of it Rolled in Bed Liner .. We were doing it in parts . .
& Yes we did pick the Hottest day of the summer 106 & 112 heat index.
Man did that 16 year old do some good work this weekend .
G-Ride990
Administrator
Administrator
Chandler, AZ
Just in case anyone hasn't seen the info on our new Truck of the Month contest, it is going on right now! Click the big link in my Sig for info!
