What is the part number for mopar antifreeze on a 2014 Ram 1500 5.7
14RAM1500BG
maryland
What is the part number for mopar antifreeze on a 2014 Ram 1500 5.7? Thanks
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
My take on Mopar OAT Coolant ....
Mopar Anti Freeze for your vehicle has at least 2 numbers
First number is for
Concentrated or straight antifreeze
The other is a 50/50 mix of antifreeze & Deionized water, is very pure deionized water is water that has had all the dissolved mineral particles removed from it.
There is a 3rd number, but it is for European vehicles like FIAT
You can use distilled water with your Concentrated coolant
Distilled Water costs right around $1.50 per gallon
Mopar OAT Coolant does not have 2EHA
Peak Global Lifetime does not have 2EHA & it is a OAT coolant
switching to silicate AF, even a low silicate one like G-05 for topic vehicle. I also wouldn't choose an AF with 2eha, so that would eliminate any Dex or Dexclone universal.
GTyankee
3.0 ecodiesel
some facts
DEX-COOL antifreeze uses two inhibitors: sebacate and 2-EHA (2-ethylhexanoic acid), the latter which works well with the hard water found in the United States, but is a plasticizer that can cause gaskets to leak.
Most Coolants Contain 2-EHA (which 'eats' silicone)​
PEAK® Antifreeze + Coolant is free of 2-EHA, silicate, nitrite, borate, and amines, ensuring maximum cooling system performance for 10+ years/300,000+ miles*.
14RAM1500BG
maryland
This is where I am confused. The dealer sold me 68163849AB. 50/50 mix 10 year/ 150,000 mile coolant. I can not find that number on any of the online dealer catalogs for my truck. I called them today to verify and they said it what is used on 2013 and up. The online catalog says it doesn`t fit my truck. I only see it used in mostly diesel truck. Whats up? Also the owners manual does not give a part number or a MS number only saying is uses 10 year, 150,000 OAT.
CanRebel
Toronto
This is where I am confused. The dealer sold me4 6816389AB. 50/50 mix 10 year/ 150,000 mile coolant. I can not find that number on any of the online dealer catalogs for my truck. I called them today to verify and they said it what is used on 2013 and up. The online catalog says it doesn`t fit my truck. I only see it used in mostly diesel truck. Whats up? Also the owners manual does not give a part number or a MS number only saying is uses 10 year, 150,000 OAT.
It's correct, what they sold you. No idea why online catalog is wrong. It's shows wrong for my 21 Rebel as well. But it is correct.
That video also shows the same part no. they sold you.
Davidloveshishemi
Tn
2019 Ram 1500 Classic
5.7 L Hemi
Dealership has what you need and it’s reasonably priced. Don’t risk getting the wrong thing. Don’t cheap out and buy something else. Get the mopar.
Dean2
Near Edmonton
Just to confuse it more, there are two Canadian part numbers for this exact same coolant too.
68175338AC concentrate and 68175339AC premix.
This thread might help.
From Tulecreeper
Looking further into it, I did find that there is a Mopar Part# and an MS#. Part# 68163848AB/MS-90032 and Part# 68163849AB/MS-12106. The MS-90032 is the concentrate, and the MS-12106 is the pre-mixed formula. They are interchangeable.
alpinegreenneon
South East Wisconsin
The part numbers were cut off in the video. I did see part of the part number which started with 6816 not the number you show
I just looked at the Mopar Chemicals Catalog again and the numbers I had in my previous post were for a half pallet of AF. The correct numbers are;
68163849AB Pre-diluted
68163848AB Concentrate
Sorry for any confusion.
