What should I expect in MPG while towing my RV
acoffeefiend
USA
I have a 2016 1500 5.7 hemi crew cab 8 spd. 275/60r20 KO2'sI pulled a 28ft keystone cougar. Dry weight was about 5800lbs, but with water, propane, camping gear, etc, it came closer to 7000lbs. I got avg 8mpg. It sucked going up any type of hill. Going up a 7% grade I was stuck at 30mph. I never drove it over 60mph when towing.
I'm now at 100K miles and am upgrading to 4.56 gears and 35" tires and a 3.5" lift. The towing capacity should go up significantly.
2003F350
6.7 CTD
It...really won't. The only thing you're helping yourself with is the 4.56 gears. Lift and tires do nothing to help your towing capacity. Gears don't change your rated towing capacity.
The only thing that can change your rated towing capacity is getting it certified by DOT.
Now, will it handle the load better with 4.56 gears? Yes. It will get up to speed quicker. But it won't stop or corner any better. Adding a lift and tires will make it handle worse when towing.
heefageLA
Vidalia, LA
05, 14, 17, 20, 23
Put this in another thread also, but the DropBox link below has a Fuel Consumption Calculator that I made. It has formulas built into it that calculate your Average MPG and Cost Per Gal. of fuel. All you need to write down when you fill up is your Total Gal., Total Cost, and Odometer then plug that into the spreadsheet. Its a nifty way to track your MPG without having to keep a written record and saves a ton of time.
Tulecreeper
Sthrn AZ
Lift and tires does not change the axes rated capacity.
If anything you're just going to make it tow worse.
Yes, changing the gear ratio will only get you moving off the line smoother. At highway speeds there will be no difference.
Randy Grant
Ellensburg, WA 98926
True, and larger tires will negate the gear change, so no gain.
tron67j
Maryland
You should go get an actual scale reading of your fully loaded rig with everything and everyone in it. With limited information to go on, best guess is you are pushing above your max GCWR. That is ALWAYS first step when towing isn't a decent experience. Throwing money at a perceived issue could totally miss the target. Higher gears are going to work your engine harder in normal use, so you may be trading up to a bigger problem long term.
acoffeefiend
USA
It's a good point, but I've done the math. 4.11 gears and 35" tires gives you the equivalent of 3.91 gears and 33" tires which was an option on my truck. Doing 75mph in 8th gear my RPMs should only go up about 300rpm with the 35"s and 4.56 gears and I'll definitely stay under the 12K that the truck is rated for with the 3.91 gears.
acoffeefiend
USA
Yup. Just want to get up to speed faster and climb hills more easily. Not going crazy on the lift. 3.5" and 35"s. Not towing any crazy weight.
The truck with 3.21 gears is rated for about 8K towing. Same truck with 3.91 gears is rated for about 12K towing.... pretty sure the only real difference in the trucks is the gearing.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
That is the only difference. That being said, going to 4.56 gearing won't increase your towing capacity. I wouldn't even tow 10k with a half ton. About 8k is the max I'd want behind a truck like that. You'll be running out of payload long before you ever get close to max towing capacity.
