WHAT THIS PART. 1988 5.2L
PaPitt
Stephenville TEXAS 76401
5.9L
so my Dodge 1988 D250 BUT MINE HAS A 5.2L. iT SPINS OVER BUT NO LONGER STARTS UP OR RUNS.
so WHILE A COUPLE OF FRIENDS & I WERE TRYING TO get it started .. ONE FRIEND WAS TURNING IT OVER & we could see a fLash of light . Like a flash each time it was firing.. This flash is coming from the passenger side of the rear of the motor. .. IT'S MAYBE 3 OR 4 INCHES BELOW THE HEAD ON PASSENGER SIDE. & SEEMS to have a pigtail that comes up into the Plastic wrapped wiring loom crossing from side to side of firewall. & I believe it bolts into the back of the motor or the back of the head. 1988 doesn't have a Crank sensor .
If you know what this is, please .. & If you know either the Chrysler number or one or 2 of the ignition parts numbers . Thanks in advance. We were wondering if it might be fuel pump related. But i DON'T THINK IT IS.
Thanks Again.
P
PaPitt
5.9L
Heck I can't get up & Back there to see it myself..BUT SURLY there's not but one or 2 items attached to the back of the block ..& going to that one wiring harness going from side to side of the firewall.
RamDiver
Marlborough, Ontario, Canada
You're talking about a 35-year-old truck and expecting that the members here are so intimately familiar that someone will guess correctly. LOL
In your first post you said;
If you saw it, why can't you make the effort to illuminate the area with a light and snap a pic?
It sounds like you're just being lazy and having unrealistic expectations of everyone's ability to guess.
Best of luck to you.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
You got a bad sparkplug wire. The distributor is in the back of the block. Sparkplug wires commonly come with loom on them.
P
PaPitt
5.9L
18 Crew ... No Sir not a bad wire.. Wires are 6+ inches from that spark.. wish It was a plug wire.. But I'd certainly not have post about a wire on here.
...... Just for the record .. The 3 of us looking at that truck that day.. HISTORY. I'm 74+ NOW & I owned a parts store Biggest of 5 in our town from 1967 until 1995+ Then a SuperVisor for an Automotive firm for the next 10 years, Then worked as the Service Advisor at the biggest Diesel Dodge truck dealership in Texas. I wrote Service for 5 or 6 mechanics . We worked on 100 Diesel Truck a week. & About 5 chrysler cars a week.
& The other 2 Guys there looking at that truck . Oldest is about 55 & been a true mechanic since he was about 18 .. Now he & His Helper are the only 2 tech at a used car Sales lot. But they receive cars & pickups from 2 other shops also . So they have both had look of experience. . I'M Expecting that SOMONE on here has had 25 318's AK 5.2L'S PULLED OUT & KNOW EVERY NUT & BOLT ON THOSE MOTORS. I used to know every bolt in a 1975 era 350'S PICKUP. i BOUGHT & FIXED SO MANY OF THEM..
so that why I ask that question. i KNOW someone know what's bolted to the back of the motor ..
But in the COLD BLOWING WIND & In the dark. We could see it flashing down there some where.
& That truck was not parked at my house it was in a back pasture of my farm.. 150ac away from my House. so it was not like it was in my drive way & I was watching TV. IN MY BLOOMERS.
........ & Finally got to talk to my Mechanic Buddy this evening at the feed store .. We're going to shoot for another glimps next week one evening.
I'll post back any info I find, maybe it'll help someone else .
...Thanks In Advance...
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Well, is the coil mounted on the firewall cowl or did it slide out of the bracket and is laying down there arcing out to ground? This makes sense since it stopped running and now flashes when cranked.
I read your background above, but I still have to run through the possibilities.
Take a video or atleast pictures and post here.
P
PaPitt
5.9L
I'm Sorry for not getting back on here.. & As everyone says I'm too busy. 75 years old & Still farming or at least checking the cows.. & This weekend I've been checking 2 different neighbors calving cows.. I went to one of my neighbors 5 times yesterday .. & Checked his special DARLINGS. Last time was 3AM THIS MORNING.
& I intended to Burn a huge Brush pile starting this morning .. But I DIDN'T HAVE MY TIME TO STAND around & watch it burn For 20 hours. But we had no wind today & It'd just came a big rain 2 days ago.. & As I say that truck in in the back of my place .. Lot's of gate to open to get there.. We may just go at least drag it back toward the home area.
.......As far as the Coil I'M PRETTY SURE it's still in it's bracket.. Because when I bought the truck Someone had cut & spliced the wire going to the coil... Their splice was worthless so I redid it.. & I remember looking at that splice But it was not touching anything. & Is a foot from the sparking area.
Daw14
Get a cheap Boroscope camera , it can get in there to get some photos.
P
PaPitt
5.9L
Well the kid that mechanics for me has the part Found & Fixed up to install..Now we've both got to get together & go to the back pasture & Install it.. He took works as A Mechanic in town. & He umpires high school baseball games after hours. So HE'S AS BUSY AS i AM.. iT'S BEEN RAINING It.s almost time to start baling & Hauling in the rounds bales out ..So I'll be needing that truck in a few weeks. Hope the Hydraulic work after it starts .
Nothing is ever easy on the farm.
P
PaPitt
5.9L
OK GUYS only took a couple of months . But JIMMY GOT OUT HERE Last Monday & he was able to get that little connection spliced into place .. & A few shots of carb cleaner & It fired up. We both agreed that we felt the Fuel Pump seems weak. & Most likely needs to be replace.. So I drove it back to the house. Killed it & It restarted back up several time . I drove it up & Down the County Road a couple times putting maybe 5 miles on it . It truly ran Fine. & The next day I cranked it again .. & Let it run for a few minutes..
Now it's rained the last 2 day. & I'm going to attempt to get it to town & Get some fresh gas into it . & Over to an Inspection station SO i CAN GET FRESH License Plate on it..
We noticed It had a bad Hydraulic leak under the bed from the cylinder on the Hay Bale Lift Spear. I'll need that Spear working properly to haul 50 or 60 round bales from the back up to my house.. That'll tAKE ABOUT 3 DAYS DEPENDING JUST HOW HOT THE WEATHER GETS. At 75 I'll most likely not last but a couple hours at a time.. Depending just how Hot it gets.
But glad to hear it running again.
P
PaPitt
5.9L
SO It wasn't raining today SO I jumped in the old 1988 fired it off & Drove into town . Went & got new wiper blades & then on to the Inspection station .. They looked it over & Passed it So down to the court house I went & I got new driver plated on it...
SO i'M LEGAL to drive it around again. MAN IT SURE DID DRIVE WELL TODAY. I'm not sure why I like to drive the old 88 but it's just a pleasure to drive..
... On my trip home I live on a 60 mph FM in the country. I Looked down & I'm doing 80+ Whup I expect i'D BETTER SLOW IT DOWN a TAD.
metalchewy
Las Vegas
2010 TRX4
4.7L
Never really heard of the 80s/early 90s fuel pumps slowing down and being weak. They usually just stop. The screen/sock however may be the culprit, but while you have the assembly out after dropping the tank, it may make sense to replace it when you do the the sock. The Carter pump on rock auto comes with the tank gasket ring.
Make sure to have some quick disconnect tools to be able to release the fuel lines.
Also while the tank is dropped, the Dorman tank filler grommet is still stocked at most parts stores. If it looks like the original is still on the tank, it may make sense to replace that too.
I just helped a friend with his 1990, and we cracked a nipple taking the old cracked fuel injection line off of it for replacement. Those may or may not be available easily. I bought a dorman one off Amazon, but it took a few days.
P
PaPitt
5.9L
Metalchewy.. THANKS for the info.. Jimmy the young tech that comes to my farm to fix most of my crazy Things I have going on.. He should have the tools, He's been mechanicing for many years . He's just a lot younger than I am..
I believe the guy I bought this truck from said He'd had to replace the pump which would now have been about 10+ years ago.
thanks
