- Jan 17, 2016
- 14,278
- 24,977
- 14 Sport
- 5.7
I have probably ran the truck for around 45 minutes wether that be idling or driving low speeds around the block. I also soaked the lifters in oil before installing them as I heard that this would somewhat help with purging air from the lifters. I did this soak for around 6 hours before installing.
If everything is in spec as far as lifters/pushrods/rocker arms etc.and working properly,ie: the lifters are pumping up properly,the only thing left would be the cam itself. I've seen that problem on reground cams or a small base circle cam,but the odds of a cam manufacture'r sending you a small base circle cam by mistake aren't really common.What cam did you replace the original with?
