seank
Hello, I've wired in some lights (fog lights, reverse lights, and bumper light bar), and need help with the switch. I've utilized wiring method B on the right in the first photo, and as I tended, the bottom backlight on the switches is only coming on when the switches are turned on. However the problem I am having is that the top backlight on the switches are on constantly, and I'd like them to only come on when the vehicle is running (second photo).
Is there a way to wire this switch so that the top backlight on the switch only comes on when the vehicle is turned on, and the bottom backlight only comes on when the switch is turned on?
What I was going to do, was disconnect the relay kit's ring terminals from the + battery terminal and connect it to an accessory switched power source using a micro fuse tap (3rd photo). Will this be okay? The fog lights only have a 3.06 amp draw, and the reverse lights are around 4.17 amps, so I was going to run two off of one switched 25 amp micro fuse slot and tap it with a 10 amp fuse for the accessories.
However, micro fuses only go up to 30amps, and the draw on the bumper light bar is slightly higher (33.3 amps, and the inline fuse on the relay kit is a 40A fuse). My next consideration was to tap one of the cartrige fuses (4th photo), which are 30-50 amps, but I can't find a tap kit for them, is there a better option?
EDIT: I used a circut tester to check all of the 40 amp (and higher) cartridge fuses and the only one that was remote on/off was for the hvac blower fan, so AC would have to be running for it to work. No dice with the cartrige fuses, and micro fuses are too low of amperage. So I'm kinda stuck...
Any input/help would be much appreciated, thank you ahead of time!!!
