2010 5.7 swap 2014 5.7
Louis M Mambrino
mastic, N.Y.
I have a 2010 5.7 hemi want to swap with a 2014 5.7. Hemi, are there any differences? Is it possible to do need some help?
HemiLonestar
MD
Same basic engine, question is why? Is your original toast?
The only differance is the crank tone ring,you can use the later engine and it's tone ring,with the earlier crank sensor (like what you're wanting to do),but you can't use the earlier engine in a later chassis with-out changing the tone ring.Depending on which transmission was behind the donor engine,you might have to swap the pilot bushing in the back of the crankshaft, The 8 speeds use a differant pilot bushing then the 5 speed transmission. Then use your original sensors and it's a bolt-in.
