5th gen tire wear
Edward Hands
Youngsville, Louisiana.
5.7 E-Torque
There is a very specific way to do an alignment on an air suspension truck. Are you sure your FS tech followed it? Truck must be set to alignment mode.
Next, what is it rubbing? If it's rubbing enough to wear the tires and for you to hear it, it has to be visible within the wheel well.
What size tires are you running? OEM rims and tire size?
On my next alignment I will be remaining in the driver seat. In part to verify that the truck is in alignment mode.
Bob will have to please confirm but I think what Bob was referring to was a the sound of the tire scrub. In the first post he said he could almost feel it in the steering wheel.
When turning, the inside tire turns at a much steeper angle as to achieve the tighter radius of the inner circle that it will follow. A lot of times these scrub angles do not coincide with the arch of trajectory that tire is on, causing increased wear. (I wonder if posi-trac contributes to this?)
Another reason that I want to be in the driver's seat, besides proper loading, is because once the alignment is finalized I would like to record how the specs change as I cycle through the the 5 different ride height modes and see if the alignment mode is actually closest to "normal" or "aero" mode.
B
Bobwilla123
Georgia
I am running OEM tires. 275/55/20. I specifically told them to tell the tech that it must be in alignment mode. This can be accomplished through the radio settings.
TC Retired
AZ
3.0 ED
I will say that is almost 2x the wear I have @ 26k. So I'd be inclined to believe it is due to alignment issues.
I would say those are about worn out. What pressure do you run in them?
And which Aero setting do you usually have it set on? Mine is left in Auto (height 2) almost all the time unless the snow is deep and then only until I get to plowed roads.
TC Retired
AZ
3.0 ED
Just talked to the local dealer. He said we need a yearly alignment and these have no special process to align them. It is a maintenance item and no warranty coverage for the issue. Also, will have to talk to a Tire shop for the mfg's warranty.
Was not impressed with his answers...
Oh and that it's $100 for the service.
Edward Hands
5.7 E-Torque
This was my exact experience at the dealership back in 2020 when I had only 20,000 miles on it and the Bridgestone's were wore smooth on the outside edge (passenger side was worse). His print out clearly showed where it had excessive toe-in on a brand new truck!
TC Retired
AZ
3.0 ED
This was my exact experience at the dealership back in 2020 when I had only 20,000 miles on it and the Bridgestone's were wore smooth on the inside edge (passenger side was worse). His print out clearly showed where it had excessive toe-in on a brand new truck!
Did both sides of the Truck have the excessive wear or just the Drivers?
Did the alignment stop the uneven wear?
Edward Hands
5.7 E-Torque
37 PSI cold. I tried higher, but it felt like the tire sidewalls weren't doing their fair share of the dampening.
I agree, I am not comfortable with the condition of that Right Front but the other 3 look something like this:
Hence the reason Bob and I are in this thread.
Originally I did not rotate the original Bridgestone's. My reasoning was that this allows you to see exactly, without doubt, how each corner is wearing with no confusion. That's how I discovered that both fronts were wearing out the outer inch of the tread. Even more so on the RF.
So I bought two new Bridgestone's, put them on the back. Moved the evenly worn but still very good Bridgestone's to the front.
Where they too wore out in short order.
At the time I was making 900 mile trips to Carlsbad, New Mexico ever two weeks. So the Bridgestone's saw 80 MPH highway miles in aero mode pretty much exclusively.
I put 50k the first year I owned the truck...
Edward Hands
5.7 E-Torque
Well... as you can see. While it slowed it down I do not feel that the front end specs have ever been where I want them.
This second alignment was just a free check when installing the two new Bridgestone's. You know, one of those "you don't pay if we don't adjust" deals.
And for some reason they didn't save the "before" measurements...
Then this was done when installing 4 new Falken Rubitrek (which are great!) 275/60/20 still on the OEM rims.
And once again no "before" measurements were provided even though this was a year later and a different establishment...
Notice that again the toe-in is excessive. And on the RF to boot!
TC Retired
AZ
3.0 ED
Just returned from Discount Tire where I had mine inspected. The first counter guy made mention that the OEM's use inferior tires.
Then talked to the Manger and he said that this has been a problem with Bridgestone's forever. They even called Bridgestone to find out if I could get any credit towards (having a sale right now) a new set of 4. They won't even discuss it until you get below 4/32s.
Mine are around 5 - 6 everywhere except the outer edge on all 4. I have consistently rotated them at close to 5k. However all 4 are down to 1/32 on that outer edge. Which I assume is all frontend wear. I hesitate to have it aligned because of the consistent wear on all other parts of the tires. All 4 are almost exactly the same.
My plan is to have them rotated side to side and see how they run. I figure I can get at least another 10 - 20k out of them. Then I think I will go with the Michelin Defender LTX M/2 for a better warranty and longevity. They claim this wear is a Bridgestone problem and that Michelin has solved it. Also that Bridgestone knows they have the problem but do not fix it.
I was also told that they are non-directional tire. So I'm going to do the diagonal rotation sometime soon.
Kickboxer
ND
5.7 Hemi-non-Etorque
This thread is agonizing. C'mon man, nobody is going to solve this
on a website.......................
Edward Hands
5.7 E-Torque
Bob, welcome to the forum.
Yours is a personal issue, tire issues like you say are not common, so don't place blame on the 5th gen. Ram. No different than any other vehicle.
If all this is too much for you just unfollow the thread.
skates15
Ohio
I plan to get Michelin Defender LTX next year. I have the OEM Bridge stones and was not satisfied with the steering wheel jitter on a new truck, so I took it in and paid for an alignment at Discount Tires. They also said the Bridgestone were not the best, but in my case they fixed the steering jitter by removing Tar that was wedged between the tire treads.
I will look into the Falken, thanks for the tip on that.
Lil' Rob
Ohio
I've got the original Falkens on my truck...roughly 28k miles...same problem with outer edge wear...I may have to replace mine soon...dealer has done all of my alignments.
B
Bobwilla123
Georgia
Trying to get mine to the dealer next week. They said they want it for a couple days. First they are going to check the alignment. If good they said the want to look at all the suspension. When I talked to the originally they said the have not heard of this issue. Now the are curious with the first replacement at 39k. I will report back once they are done.
1stindoor
NC
'23 2500 MegaCab
Granted I have a heavier truck, but on my first Ram 2500 (2018) I noticed the OEM tires didn't last long at all. I usually drive with either Nitto Ridgegrapplers or BFGs. As soon as I took delivery of my current truck I sold my OEMs to a friend of mine for $400 and put Nittos on it. I usually get around 45-55k miles out of a set. Rotate every oil change.
Edward Hands
5.7 E-Torque
Update but not the end of the saga...
I went to an ALIGNMENT shop, not a tire store or the Dealership. That's like going to a Podiatrists to have your teeth cleaned. Sure he's a doctor but...
Anyhow, I was severely pigeon toed.(see photo) Which could have been partly from removing and reinstalling the front struts at home. But I feel that excessive toe-in has caused outer tire wear on the front from day one.
This is the fourth alignment that was performed on the truck and the FIRST one that left the shop with proper toe-in set.
B
Bobwilla123
Georgia
Well I finally got my truck into the dealer. Their tech said my toe is off I believe they said .5 degree. No worn parts so apparently it was that way from the factory since I have had this problem early on. They will do the alignment today and I have asked them for printouts before and after when I pick it up. I will post them when I get it back.
B
Bobwilla123
Georgia
I picked up my truck from the dealer today. The first attachment is from the dealer before and after. Apparently the alignment was incorrect from the day I took possession of my new truck. I also attached a copy of the alignment check from Firestone which showed all in spec so either their rack is not calibrated correctly or they never put the truck in alignment mode for the air suspension. I will give an update after I put about 5k more miles on the truck.
Edward Hands
5.7 E-Torque
Bob, thanks for the update.
Let's see how this wears. I believe that excessive toe-in from the factory has caused many to have excessive outer edge wear on the front tires.
I'm going to have mine checked again, at the same alignment shop, just before I put new tires on.
I'm anxious to see if the toe-in remains the same. It will be hard to tell since the wear is already so uneven but,
If it seems that the outer edges are still wearing faster than the rest of the tread then I will ask them to dial in more negative camber.
