87 D250 Upper Control Arm 3300lb Axle
bryank87
Carbon Hill, OH
5.9L Gas
I just bought an 87 D250 5.9l gas. I have searched high and low for a passenger upper control arm. The one on the truck has rusted through. I keep reading about differences between 3800 and 4000 axles. Mine apparently has the 3300. Some I have found online has the cross bar that has 2 bolts to the frame. I just looked and mine doesnt have this. Any advice would be appreciated. How to find one, what, or if any other model will fit?
Fast69Mopar
Can you take a picture of what the right front upper control arm looks like? You gave a couple of options that you can use with upper control arms from a later model D250/D350. I need to know what yours looks like exactly though.
u2slow
BC, Canada
Cummins 6BTA
The uppers should all be interchangeable D150-D350 so long as you use the appropriate balljoint.
B250
Rhode Island
5.2L V8 MFI
I had a rusted drivers' side control arm (see profile picture) which I had no trouble getting from NAPA. Even though my B250 carries a lot of extra weight (converted to a motor home) the front axle is a standard duty one. The control arms on these ram's are notoriously 'weak' but a Google search should produce some sources online. Tried rockauto.com?
I found the bigger problem was finding someone who could do the alignment afterwards
B250
Rhode Island
5.2L V8 MFI
Just had a look at rockauto.com for my year B250. Control arm is not listed for the D250 but is for the B250. The base design of the B250/D250/W250 are the same
wyobigchief
