Canadian truck It's possible to change 3.5 to 7 inch cluster
Michel1956
Trois-Rivieres, Quebec, Canada
Hi, I bought a 2023 ram 1500 classic 3.6 in Quebec, I want to change the speedometer cluster for a 7 inch. The dealer told me that I would have to change all the wiring and that it would cost too much. I would like to know if someone from Quebec or Canada has already done this. Thank you so much.
Atcer2018
Virginia
Reach out to M2 Mods in the vendor section. He is our resident wiring upgrade specialist. If he can’t help you he may have an associate that can.
I swapped the small cluster out for the larger cluster on my old 13,and it was plug-n-play,and i'm in Alberta,and the truck was definitely a Canuck truck.I don't think much has changed since then.You can't use the clusters from a 12 or older though.
Administrator
^^^ what he said
You'll want a cluster that close to the same year. You'll also need AlfaOBD (w/OBD and security gateway bypass cable) to update the mileage and engine hours.
