I never lock out my OD gears, haven't regardless of what truck I've owned and never once had transmission issues. If it needs to shift out of them it'll do so. I just set the cruise at 65 and let 'er run.
Pulled a 10k fifth wheel with my '99 F250, 7.3 auto all over the state. Only time it DIDN'T run in OD I was pushing about a 20 mph headwind, it pretty much stayed in 3rd, on a tuned truck that turbo whistle got kinda annoying but it got the job done, no heat issues.
Pulled that same camper with my '03 F350 6.0 auto. Held OD better, would drop to 4th on big hills but no issues with heat or trans slippage. Put over 100k on that truck as a daily driver. No tune, no delete, no bulletproofing on that truck, only issue was rust.
Switched campers and trucks and got an '04 F350 dually, 6.0 auto, to pull our 42' Cyclone tri-axle toy hauler (18k GVW I think? Big heavy camper). Tow/haul didn't lock out OD, so it would shift into it on flat ground. Pulling grades it would shift to 4th, I don't believe it ever went to 3rd pulling a grade in this state. Ended up tuning and bulletproofing that truck because I was pulling heavy with it, only issue I ever had was failed injectors. Pulled like a freight train.
Got away from the toy hauler and got a smaller lightweight travel trailer (same one as now) and pulled it with the Wagon. It would go into 6th on flat ground, preferred 5th while pulling smaller hills, big hills would see it drop to 4th and scream at 3k+. Wife thought it was going to come apart, but she was used to the lower-revving diesels I had previously. Again, no issues with heat, no valve body issues, no wiped out cam/lifters, probably the best truck I'd owned to date. MAP sensor and 110k saw me needing a new truck.
Picked up my '22. First trip with the camper was at about 2k miles on the clock, ran across the state on a mix of expressway and state highways (55-65 mph). Once we got to speed I don't think it ever shifted out of 6th. Even pulling the bigger hills up north it only built 10 lbs or so of boost and stayed in 6th. Haven't seen over 180 on the trans temp.
If you're pulling really heavy all the time in the hillier parts of the country, by all means lock out 6th if you feel you need to. But they've got these trucks set up to protect themselves in their stock form. They are built for people to just get in and drive whether you're pulling or not. I do agree that there should be an even more de-tuned version of the CTD, as not everyone needs the 850+ ft lbs of torque even the SO has, most could get away with something closer to 500/600. With the exact same trans behind it, it'd last forever. Of course, they can't sell new trucks if the old ones don't break.
I owned ,and towed with a 99 Superduty 350 7.3 for nearly 16 years . I did everything that was fairly practical to that truck ,bagged it for towing a fifth wheel . AIS intake ,DP tuner , 4"turbo back exhaust . 6.0 intercooler ,and tranny cooler , gauges to monitor boost ,ETG's , and transmission temp . Great truck ,just didn't have it towing a bigger fifth wheel in the mountains . Locking out OD on it , with the head winds , steep grades etc ,it was in third a lot of the time , no need to lock it out of fourth . It didn't take a whole lot with towing to kick that truck out of fourth . Did okay towing 9-10 K , not great , but jumping up to much over that ,that 7.3 fell on its face . Plus that 4R100 transmission was one of fords worst .
