Engines compatible?
Shanelive13
Jackson MS
06 Ram1500 3.7 Magnum engine replaceable with a 08 Jeep Liberty 3.7?
Vin engine code matches.
Simple swap?
Daw14
It’s here. I have no answer for you , someone who does should be along shortly.
White six four
Wisconsin
Just a quick check on car-part.com for an engine for 06 ram with a 3.7 most of the engines that come up on the search are from jeeps and a few liberty's so I would say yes based on that data. You could call a local junkyard and they should have compatability charts or whatever they're called to make sure.
S
Shanelive13
Jackson MS
Thank for the help. That's kinda why I asked. Any idea why the 08 Jeep 3.7 takes a lighter oil than the 06 Ram 3.7? Are the sensors backwards compatible? Will I need to swap the control modules and or computer as well?
jws123
nj
You can swap it no problem however You need to use your old oil pan or just get a new one the ram pan is diffrently shaped.
Daw14
Lighter oil is for .002 % fuel mileage increase , to meet govt. requirements.
aszumilo
Las Vegas
According to my local pick a part (nvpap.com), fitment is as follows
  • DODGE 1500 PICKUP 06 3.7L (VIN K, 8th digit)
  • LIBERTY 06 3.7L (VIN K, 8th digit)
Not to say other year engines wouldn't work, but, you'd probably have to change some things like sensors and maybe some hard parts like oil pan.
S
Shanelive13
Jackson MS
Thank you.
The donor Liberty is an 08. (If that matters...)
Oil pan bolt pattern the same? Any jeep sensors shaped different that Dodge harness won't match?
I intend to use the pan and sensors from the Dodge.
