Four channels amp install
garnut
Crabtree, Québec
Hi,
I would like to install a four channel amp without connecting behind the radio. I know where the wires go for the rear speakers. But for the front speakers where are these wires accessible?
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
Front speaker wires are accessible behind the radio or at the doors. You're further ahead to just connect behind the radio in the first place everything's there. You will need load resistors also because the minute the head unit doesn't see the speakers connected to it. It will throw an error and shut down the signal to those speakers. So it's not as simple as the old days when you could just connect the speakers to a new amp.
G
garnut
Crabtree, Québec
Thank you! I would never have understood why there is no sound. So it is important to install these resistors
canadiankodiak700
3.7L Pentastar
Yes, it's important. The OEM system is load sensitive. It needs to see resistance from the speaker or a resistor. Otherwise it will shut down each channel that has no load
