how to disable auto unlock
nanvanplan
I have a 2017 RAM 1500 that is not key fob capable. With auto unlock enabled, I must either lean across the cab or walk around the vehicle to lock the passenger door... super annoying!
The option to disable auto unlock is not available in the menus of the instrument panel or the center touch screen. The only procedure I have found online involves turning the key in the ignition multiple times and then using the lock button on the door armrest... which I do not have. I visited a dealership today to get a spare key programmed. I asked them to disable auto unlock. They found the option for auto lock, but not auto unlock on their computer.
Has anyone solved this problem?
RamDiver
Marlborough, Ontario, Canada
Welcome to Ram Forum. :cool:
I would suggest you scan the AlfaOBD section for a solution. I haven't found anything anywhere yet.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Which radio you have? There should be a setting in the settings menu for that.
If there isn't, check AlfaOBD for:
Cust.Set.Menu 1:
Auto Door Unlock CSM Present: Yes
PS: Should delete your other duplicate post about this.
