loss power
3500failer
virginia
6.7 diesel
engine light on pay dealership to fix loss power paid a lot of money to have it fix did not get 20 miles engine light back on loss power going up incline. took it back said charger air cooler had that replace still have loss power. like turbine not kicking in. need some help here please.
06 Dodge
Forest Grove, Oregon
6.7L CTD
You really need a new dealer or an independent shop... Do you know what the trouble codes are? I can only assume they put that info on the paper work they gave you when they finished the repairs, having that info will help others help you...
3500failer
virginia
6.7 diesel
Codes p1507,p2002,p2202,p2209,u059e and p020d, dtc p2281. Took it in October 5th said loss of power engine light on ticket just had engine light on no loss of power. Got it back October 26th took it back October 27th
Fuel35 67
Hanford
P1507 CCV filter is more like clogged
P2002 Clogged DPF
P2202. Nitrogen Oxide Sensor
P2209 NOX Sensor Performance
U059E Invalid Data received from NOX Sensor
P020D Injector on Cylinder 4 (bad?)
P2281 Air leak before the MAF Sensor and Throttle Body.
I’d start looking over every clamp to make sure they are tight.
3500failer
virginia
6.7 diesel
Okay Thx’s I’ll get on in the morning hope that works.
Fuel35 67
Hanford
And what have ya found?
