New to Ram forum
Ritz55
Elkhorn
Hello,
I am new to the ram forum and had a question for my 21 Laramie. I have a left taillight out. I assume due to moisture in the casing. The brake light and indicator work fine. Just the park light doesn't. I was told with the cross path sensor that the whole assembly needs replaced since there are no individual bulbs to replace. Before I go paying $500+ for a new assembly, I want to verify this is correct.
Taillight for reference below
Black-Wolf
North Carolina
If your tail light is LED (as in completely LED - which I believe it is in the 2021 Laramie), you will need to replace the whole thing. However, that being said, I'd check the warranty - you should have at least a 3-year warranty, and moisture getting in to the tail light so soon, indicates that there was a manufacturing or assembly defect. Contact your dealership and complain.
