- Apr 20, 2018
- 3,063
- 2,659
- Location
- Central NY
- 2018, 2019
- 5.7 Hemi Big Horn, 6.4L Hemi 3500 Longhorn Mega cab
Maybe this can become a sticky, not going to give any opinions or conjecture. Just a start where to look stuff up to find cargo & towing information.
This is the location of the cargo capacity sticker on the driver's side door jamb.
This is what it looks like and has the cargo capacity listed in Kg and Lbs.
This sticker lists the information for your truck, VIN, axle ratings and Gross Vehicle Weight. This is on the driver's door.
Curb/base weight can be figured out by subtracting the cargo/payload from the Gross Vehicle Weight.
Using the info in the two images, 14000 - 6292 = 7708 gives you the curb/base weight.
To find out what equipment you have for your truck, you can check here:
This will also give you the gear ratio for your truck.
You can find your towing capacity by looking here:
Enter your VIN and see what is listed. It only goes back 5 years I believe.
Another way of checking your tow rating, is by looking up your truck on the Ram Trailer Towing charts. You have to know your gear ratio. Using the chart, the example has a 3.73 gear ratio. Mega cab dually, 6.4L Hemi, 3.73 gear ratio, 4x4, has a Gross Combined Weight Rating of 21500 lbs. Subtract the curb/base weight from the Gross Combined Weight Rating to find the tow rating.
21500 - 7708 = 13792.
2019 Trailer Towing Charts:
RAM 1500 Classic:
RAM 1500 DT: https://www.ramtrucks.com/BodyBuilder/service/Image?imageId=MtQrP/FqLY5r/est8MtGjGgHzAHGUTU0WB3rWuqSY7YmQ2vEhuBWBAvoEbjA+c5q
RAM 2500: https://www.ramtrucks.com/content/d...ow_Excel_2019_DJ_OFFICIAL_INTERNAL_2-6-19.pdf
RAM 3500: https://www.ramtrucks.com/content/d...w_Excel_2019_D2_OFFICIAL_INTERNAL_2-06-18.pdf
RAM 3500 4500 5500 Chassis Cab: https://www.ramtruck.ca/en_dir/pdf/Ram_ChassisCab_TowingPayload_Chart_EN.pdf
2020 Trailer Towing Charts:
RAM 1500 Classic:
RAM 1500 DT:
RAM 2500: https://www.ramtrucks.com/content/d..._HD_2500_DJ_Trailer_Tow_Weight_Chart_MY20.pdf
RAM 3500:
RAM 3500 Chassis Cab: https://www.ramtrucks.com/content/d...g/Ram_CC_Trailer_Tow_Weight_Chart_MY20_R1.pdf
RAM 4500:
RAM 5500: https://www.ramtrucks.com/content/d...g/Ram_CC_Trailer_Tow_Weight_Chart_MY20_R1.pdf
2021 Trailer Towing Charts:
RAM 1500 Classic:
RAM 1500 DT: https://www.ramtrucks.com/content/d...am_LD_DT_Trailer-Tow-Weight-Chart_MY21_R1.pdf
RAM 2500:
RAM 3500:
RAM 4500:
RAM 5500: https://www.ramtrucks.com/content/d...wing/Ram_CC_Trailer_Tow_Weight_Chart_MY21.pdf
2022 Trailer Towing Charts:
Still searching for the ramtrucks.com trailer towing charts for 2022.
FCA RAM
fcacommunity.force.com
Ram Towing | Find the Best Truck for Your Towing Needs
Find everything you need to know about Ram towing capacity, payload & more here. Discover the best Ram truck or van that fits your towing needs today.
www.ramtrucks.com
RAM 1500 Classic:
https://www.ramtruck.ca/documents/ramtruck/specifications/2019-ramtruck-1500ds-specifications-en.pdf
RAM 1500 Classic:
RAM 1500 DT:
RAM 3500:
RAM 4500:
RAM 1500 Classic:
RAM 2500:
RAM 3500:
RAM 4500:
