Pentastar oil leak, is this a common spot?
ramrod_2023
Mid West
Hi to all, can you help me identify what may have caused this leak? I noticed a drip on the driveway, looked underneath and the entire transmission and pan was covered with oil. I thought it was a transmission pan gasket failure, but upon examination, it was engine oil. I cleaned everything off and now can see where it's coming from. It's not the oil pan, but it's (part of the engine) where the oil pan mounts to.
Is this a gasket failure? Fortunately I've still got a warranty, but is a big job to replace this gasket, assuming that's what it is?
Thanks in advance!
danielmid
Southeast WI
2015 Sport 4x4
Thanks in advance!
If it's under warranty, why are you asking how much work it is? Have them fix it, then tell your oil change person or place to stop over tightening the filter cap.
I've yet to see a compelling reason to swap to the spin on filter adapter.
R
ramrod_2023
Mid West
I looked again today, and I see the majority of the oil is in fact coming from somehwere on top of the bell housing. I can't see where without a camera. Is this further evidence of the oil cooler leaking?
danielmid
Southeast WI
2015 Sport 4x4
It's under the upper intake manifold on the top of the engine, use a flashlight and you'll probably be able to see some shiny reflections down in the valley.
