Radio blares loudly at Startup
Ran White
Georgia
6.7 Diesel
When I start my 2019 Ram 2500 with the small screen display the Radio comes up FULL VOLUME and volume knob, off button, does not respond. Turning off the truck will shut it down, but radio has loud static until I open door to remove all power to console. This happens several times, then it will come up “normal”. While it is in the blaring mode, when you press the start button the engine starts WITHOUT pressing the brake. ANY IDEAS WHAT TO DO TO GET THIS FIXED? I know it will be a “can not duplicate” at the dealer and I will have to pay for a diagnosis with no results.
RamDiver
Marlborough, Ontario, Canada
The first place to start is load testing the battery regardless of age. Then, checking connections and grounds. That's my first thought unless someone can speak from experience on these coinciding failures.
bushyrem
2019 Ram 1500 Classic. When listening with the key off (after you first have shut the engine down) the radio randomly comes on full volume for a few seconds then back to normal. It never does this whie driving and isn't much of a problem but it sure wakes me up when I'm trying to nap.
