Replace engine driven Rad. fan with electric?
tron67j
Maryland
Not aware of any kit, you will need to build your own set up. What is happening with your current setup that you want to add a electric fan?
CorDog009
East Texas
Just find one that’s the biggest you can fit inside the fan shroud. Then decide if you want to use a thermostat switch or just manually activate it.
PigPenCO
Colorado
