specs on Alignment with rear adjustable control arms
Dilligaf-23
austin, tx
I put a 2/4 drop and core 4x4 adjustable rear control arms. stock 22" wheels. Keep having troubles of where it needs to be adjusted to. Does anyone have alignment specs for this setup?
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
My suggestion is to start at stock length for upper and lower. Check you pinion angle to see how far its out then develop your plan for adjustment.
I don't think the lowers are long enough to Center the rear wheels and if they are you uppers will run out of adjusting for pinion angle
That's why a lot of lowered rams run the Inez brackets.
DILLIGAF
Canada
All you need is an angle finder, Find your output shaft angle and adjust your bars and match it to the rear diff .
Check that your axle is still centered in the frame and adjust Panhard bar accordingly
