Traction control warning light. How to reset
Arthurw
Missouri
I have a 2015 Dodge Ram 2500. Blew a fuse for tow turn signal (easy fix). Buddy pulled the wrong fuse. Pushed it back in and changed the right fuse. The traction control warning light came on and won't go off. Can I reset this somehow? I know there is no issue with the truck. I would like to use my cruise control.
Dodge 1500 4X4
Rochester, NY
Disconnect the negative battery terminal for 30min or so see if it clears, if there's a check engine light (MIL) you need a scanner to reset it, Autozone has one.
