Yes they are OEM. Did you have to grind the weld stake spots,off and remove the cap and press them out ?My OEM ball joint did not have a snap ring. The aftermarket version that I put on did have one. I'll bet that either they haven't been replaced before, or if they were, OEM ball joints were used.
If you install ball joints that have grease fittings, make sure that you orient them so that the fitting can be reachable for periodic service. I neglected this step.
No, I just pressed them out with this...Yes they are OEM. Did you have to grind the weld stake spots,off and remove the cap and press them out ?
