replaced lower ball joints with moog question on greasing
Shawn Burns
Lewisburg, PA
2016 Rebel
I replaced my OEM front lower ball joints with moog problem solver joints part #K500286. They have grease fittings on the tops of the joint that I am not familiar with. They are not the zerk fittings that I've used before. You can see a photo of them here (it is the second photo). https://www.rockauto.com/en/moreinfo.php?pk=7509388&cc=3353659&pt=10070&jsn=814
What do I use to grease them? I thought this might be my answer. https://www.amazon.com/Dispenser-Fi...8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Thanks in advance.
bm02tj
B C Canada
Yes that is also what you grease centering ball in front drive shaft if you have a 4x4
