Vehicle Phone Needs Service
Crisiscwby
Chicago suburbs
My radio screen says "Vehicle Phone Needs Service". 2014 1500 Sport. Lost steering wheel controls, SD card read, Bluetooth capability and Sirius radio. Only am/fm operable. Have done soft reset, hard reset and spoke with Uconnect. Software up to date. Dealer has no clue what's wrong. Wants to try replacing modules at my cost. Anybody run into this problem?
Read this post, knowing that i know little about this subject
I believe the reason for that message, is that the
3G sierra wireless card modem
The vehicle phone is actually a part of the radios printed circuit board
It uses the vehicles VIN as its identification
The buttons on your mirror, 911 an Assist are part of the vehicle phone
The vehicle phone modem is how you receive satellite updates
Warning;
when the dealerships try to repair this fault
If everything works well that is radio controlled, AM/FM, Steer Wheel controls & buttons, etc.
During the repair, the whole radio may get bricked, then it is worthless.
some owners just want the message to go away & don't want the vehicle phone, just want it disconnected
I have no comment about this write up:
UConnect Disable Cell Modem​
Author: David Zimmer
Date: 06.21.19 - 5:53am
C
Crisiscwby
Chicago suburbs
The only thing that has "changed" on the vehicle within the last 6mos is, I replaced the OEM puddle lights with aftermarket LED puddle lights on the mirrors, which now give an error message and blink quickly. Think that may be a cause???
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
I just started to get this message this past week. I assume I can ignore it? Last thing I want to do is go to the dealer. My radio did seem to reboot today. Everything was dark then after a few minutes the display and A/C buttons lit up properly. Still getting the periodic message.
give it a day or two
several people get an update & it takes a day or two for it to start working correctly
HarryS
Clovis NM
I installed an 8.4 in my SLT and have been getting this message on an intermittent, but consistent basis. Is it because the VIN hasn't been set in the radio? I have the 3G dongle from M2 Mods installed. How can I turn it off?
It may be that since 3G no longer works..
You may need to update to 4G Lite
Check to see what your cell phone operates at ...
3G , 4G Lite , or
HarryS
Clovis NM
My cell phone operates on 5G, what does that have to do with the vehicle phone? How do I get 4G lite in the truck?
