- Joined
- Nov 3, 2016
- Posts
- 2,976
- Reaction score
- 4,181
- Location
- The Palouse
- Ram Year
- 2020 Limited
- Engine
- Hemi 5.7L
As stated several times throughout the thread, it's a theory. No one has been able to prove that disabling MDS causes more lifter wear. Just like it's a theory that MDS is the cause of lifter failures. People come out with videos to present their theories on lots of stuff. And may provide some anecdotal evidence. But they rarely provide conclusive supporting data. Sometimes theories are all we have to go on. All you can do is base your decisions on what make the most sense to you.Thinking about it more: if increasing idle to 750+ helps, then why does disabling MDS matter? Either it gets lubed enough at 750 rpms, or it doesn't. If disabling MDS is damaging the lifters at 1200 driving down the road then there is no point in increasing your idle rpms.
Either the crank throws enough splash at a given RPM or it doesnt, so those 2 ideas kind of conflict with eachother, right?
Same with combining "no idle" with increase idle rpms. If raising your idle helps, then it should be able to idle for hours with 0 issues.
Just the more I think about it the more confused everything seems.
I still think this is like a wheel bearing; some wheel bearings fail at 50k miles, and the others on the truck fail at 150k miles. Nobody starts thinking there is not enough cooling/air flow to the wheel (or whatever), we just accept its a bad/poorly made part that failed before its time. Yet with lifters we're all so eager to find overly complicated theories and solutions.
