2015 ram 2wd lift question
jake0207
Eco
I've got the RC levling kit and now i want to get a lift kit what are my options?
Can I just get spindles?
J
jake0207
Eco
Wanting to get something between 4.5 and 6.5.
So I've got the rc level on the front stock on the back.
Nick@GotExhaust
Preferred Vendor
SC
Maxtrax lift kit is the way to go for 2wd RAMs, they make one specifically for the EcoD too. You need more than spindles, you also need extended brake lines, rear coils sway bar and track bar brackets, different length rear shocks, etc...A proper lift is something you should not cheap out on. It will effect reliability and ride comfort. If you are going to do it, do it right and spend the little extra money on a quality brand that offers quality products.
Message me and I can offer you a quote.
J
jake0207
Eco
I did see Max tract have a couple different versions what's the difference between eco d and just normal 2wd?
Kid's HEMI! !!
been running max 7” for like 8 years now no problems what so ever other than wheel bearing but that would be from the wheels and tires
