help needed
  1. C
    2013 ram bad hesitation need help no engine code
    2013 ram 2500 5.7 gas 210 000 kms very bad hesitation when accelerating at low speeds from a stop always around 20 to 40 km speeds no issues on highway or if i floor it, it takes off i have no engine codes other then a low voltage on gas pedal but i replaced it code still remains i have...
  2. J
    2015 ram 2wd lift question
    I've got the RC levling kit and now i want to get a lift kit what are my options? Can I just get spindles?
  3. Nawfmemphis
    4th gen 8.4 Uconnect and PAC ampPro
    *first post* I just installed two kicker cvt 12” on a kicker cxa 800.1 in my 2016 ram 1600 big horn 4x4 I got last weekend, using the pac ampPro device. And it sounds like pure D ****! The bass is muffled and no matter what I do I still kinda get highs coming thru my subs. And when I turn it up...
  4. C
    AGS Check Engine Light Nightmare
    Hi guys, I know there is a few threads about this. But I'm looking for advice with my specific experience. I have a 2016 Ram 1500. I had a check engine light turn on, ran the code, and it turns out it's my Active Grill Shutters... Apparently this is a common issue with not very common...
  5. P
    06 1500 lock cylinder component identification
    the other night there was an attempt to steal my truck and a lot of the immobilizer parts and the lock cylinder parts where damaged am having touble identifying a part if anyone has any ideas or part numbers would be much appreciated
  6. D
    Transmission won’t engage
    Greetings , I was driving down the highway at about 55 miles an hour came out of a tunnel that has a bouncy bump and when I hit that the truck lost all transmission. No oil , and no burnt smell, fluid level good
  7. N
    WIN Module Replacement
    Ok, so I had a can of compressed air that was on the floor by the gas pedal spontaneously explode and it somehow went around the bottom part of the dash and totally obliterated my WIN Module. I have a 2011 1500 SLT 4.7, I have access to a WIN out of a 2014 Ram 1500. Obviously they changed things...
  8. Y
    1500 smoking exhaust and loud hemi tick
    I bought my truck from my parents a couple years ago but I mainly drove it throughout highschool, I recently replaced the driver side head because it was over heating and found out there was a crack in it, after replacing it it’s barely been running and it’s been smoking out of my exhaust when I...
  9. 3
    Help power cuts out while driving engine stays on
    So I have a 02 3rd gen 4.7 dodge 1500. Just today I was driving floored it to get onto the highway and once my truck passed 4000rpm. Everything electronic turned off on my dash my radio everything. The engine stayed on and as soon as I let off the lights and everything came back on. There was...
  10. SugaryClapz
    Need help with wiring!
    I’m trying to wire up a drl with 2 wires going to a connector in the fuse box but one wire is too short. How do I splice the shorter wire to the longer one so they both are connected? Pic 1: longer wire Pic 2: short wire
  11. Raam
    2015 Ram 1500 5.7L Transmission Problems
    I have a 2015 Ram 1500 5.7L with 139,000. Recently, I have been experiencing issues with shifting between 36-40mph. As I slowly gain speed to 36mph, my truck doesn't know what gear to be in and will SLAM back into 2nd? gear, sends the RPMS redlining. I can power through 40mph and it wont do it...
  12. jacoblane216
    Tire advise needed please help!!
    I’m getting ready to order wheels and tires for my rumble bee, I’m gonna get either the 22x10 hellcat replicas or the 22x10 srt-10 replicas, I have 2” drop shackles in the rear and plan on new bilstein shocks in all four corners. I wanted to know what tire sizes to get for my wheels and not have...
  13. nevinwright43
    Glow Plugs and Electric Vacuum Pump
    So, some background information: 2015 Ram 1500 Ecodiesel 3.0, DEF deleted. I bought it used with 220k (140k miles) on it. Recently, I had a diesel shop replace my engine timing cover (due to it leaking). After the replacement I drove it about 130km and my fuel injector line burst and sprayed...
  14. B
    She’s lived a long and adventurous life
    I’ll be Ramin or Dodgin until I die. Grew up bouncing around in a loud 24 banger ask my grandpa to flip to the B side of “The best of ZZTOP” bought my dream truck with 24,000 miles on it. 2013 Ram 1500 Laramie Longhorn. She changed my life, freezing my butt off just to lay my hands on her warm...
  15. E
    Transmission Issue 2014 Ram 1500 Outdoorsman 3.6L V6
    Okay so as I posted in an introduction post, I just picked up a 2014 ram 1500 3.6L V6 with about 213000km (132000mi) and I seem to be having an issue with it, so I'm hoping someone here has had a similar issue or may know what to do about it. I don't know if this is where this post belongs but I...
  16. Dark Knight 500
    Dead switches and random codes
    I have searched high and low for an answer to my problem. I noticed today that my 4wd switch, lower instrument panel switches, rain sense wipers and auto high beams were all dead. I used alphaobd to read codes and found U1009 & U0213 in the BCM. I had recently installed tow mirrors and used...
  17. C
    2000 2500 NO BUS HELP GAUGES DEAD!!!
    Good morning! I'm having a hell of an issue with my truck. I've got a 2000 ram 2500 ext cab long bed with the 5.9 and auto trans. It's the Laramie model, but does not have every bell and whistle. I stopped at the package store over the weekend, shut the truck off, and when I came back out and...
  18. C
    Need some advice
    Hi, my name is Corey. I'm 18 and going on 19. Recently I got my first ram. It's a 1991 Ram 1500 square body, V8 Engine, and had some work done to it. The wire situation is crazy on the inside and out. Fuse-box is so faded it's crazy. I've had a few problems with it since I got it but I'm...
  19. T
    Random Oil Pressure Readings & Hard Start (Before and after engine rebuild)
    To begin with, about 3 months ago my 5.7 liter hemi 2005 dodge ram 1500 ran into a massive amount of problems all in one day. These issues were, loud knocking, stalling, misfires, hard start, and many other things. One of the smaller issues was the oil gauge dropping to 0, this would eventually...
  20. Brevan
    Im stumped. please help!!
    03 ram 2500 5.7 2wd So I was headed to do a job and truck starts running real ******, out of nowhere. Dummy light is flashing, "ok got a misfire.. I'm not quite due for plugs and wires yet" bust out the scanner and its just 0300.. no cylinder is labeled nothing i.e. 0304, 0307 etc. Checked...
  21. L
    help diagnosing truck after trip.
    i have a 1999 ram 1500, start from the top, i took my truck and car trailer to help my fam get a bike, but the seller declined the offer so we went home, the engine only has 30k but the transmission is original on the way home from the trip the transmission started having issues shifting, i...
  22. H
    Correct Freon for 2014 Ram 1500 Slt 5.7 Hemi
    So I had a couple of freon's and I tried them all and they do not fit on the fill tube part. I searched online it says Ram takes a different kind then I check again it says it takes the regular 134a's. Can someone send me a link of where I can get the correct freon and my freon is completely...
  23. C
    Vinegar Smell...Please HELP!!!
    I have a 2019 Ram 1500 that has a very distinct vinegar smell coming from the vents. Smells is so pungent that its like someone left a jug of opened vinegar in front of the vents. I am concerned because I have two toddlers and am not sure what they have been breathing. This has been going on...
  24. BigBlue06
    I'm definitely an idiot when it comes to wiring.
    Here's what I got that I want to eventually go into my 2006 ram 1500. I have a Pioneer FH-S52BT, 2 10" kicker subs, and a 1000W Jensen amp. I am currently having issues hooking the Pioneer FH-S52BT and I am thinking it is the wiring harness that I bought from amazon which is the RedWolf harness...
  25. A
    EcoDiesel No oil pressure
    I have a 2015 ram ecodiesel. I was recently going on a trip and got about 30 miles from my destination when I decided to make a quick pit stop. Truck was running fine. Then it started saying no oil pressure when I started the motor back up. If I gave it fuel the oil pressure would go up and the...
