Check out YouTube really easy! Btw: I never pull the grill! I have a 10mm magnet socket with a long extension to get the bottom bolt!
I ended up taking the grill off and the headlight came right out.
I also used a long extension in an attempt to take them out without removing the grill and it did not work .i believe the problem was that the bolt that I used the long extension on would not come out of its hole as I did not have a magnetic socket and the bolt just kept on spinning even though I could tell that the threads were not engaged in the hole.
I think that if I had a magnetic socket or a magnetic bolt retriever that the bolt would have pulled right out .
In any event there were no issues at all just removing the grill and removing the headlights.
