indept
- Joined
- Sep 10, 2017
- Posts
- 3,232
- Reaction score
- 4,797
- Location
- South Jersey
- Ram Year
- 2017
- Engine
- Hemi 5.7L
Yup, not sure of any other way to get the actual numbers. I think the idiot gauge just says H & L, right?Ok thanks. Just to be clear though you are checking your digital readout in your information display? This picture is at idle after I put things back to stock. Oil was still not up to temp but the Pacbrake setup would have dropped to the lower 30s at this point.
Pacofortacos can you describe briefly the installation process for the:
Oil Filter Adapter - Mopar (4893402AB)
Does it bolt right up? Any difficulty with installation?
Thanks for any tips or advice. I’ll likely go this route at my next oil change. I like the mopar unit as it wouldn’t cause warranty concerns.
Oil pressure for a Ram 1500 5.7 Hemi should be around 42 pounds per square inch (psi). Most car manufacturers recommend that oil pressure should be around 30 psi when idling and about 60 psi when the engine is running at higher speeds. We have many threads that have identified 30 for the Ram is too low long
