Wheel and Tire Change
tsjazz2002
South Carolina
Good Morning, I currently have the OEM 22 inch forged black wheels on my 2020 Ram 1500. I have the opportunity to purchase some 20 inch wheels in a style I really like. My question is, will going with a smaller wheel and higher profile tire improve my ride quality? I currently have 285 x 45 R22s on the truck and am looking to go to 285 x 55 x R20s. Thoughts????
DanAR
Arkansas
Technically and in practice a higher profile tire will ride better than a low profile due to more sidewall to absorb bumps and jolts. But from 22” to 20”, I don’t know if you will notice a lot of difference. Any difference could just as well be a characteristic of differences in the tires. But maybe.
diymirage
Get the smallest wheels that will clear your brakes
Ride quality will improve and your truck will actually look like a truck and not a metrosexual pavement queen
KKBB
Oakland Ia
The half tons ride amazing either way. Put whatever wheels and tires on you want. The ride won't change much because it is already a great ride.
T
tsjazz2002
South Carolina
Funny you say that because I am definitely a pavement queen and maybe when I was younger I was a metrosexual. Not so much any more now that I am old and chunky. So really you could have answered that question without passing judgement. FYI..... I am also former Special Forces so big tires and jacked up suspension doesn't make you tough. Life does!
diymirage
You asked a question, I answered it
I presume in the special forces they taught you the importance of the right tool for the right job ?
Administrator
Tire size won't change much to effect the speedo/odometer
The factory 20" is a 275/55/20, which is the same diameter as the 22" OEM 285/45/22 size, the 18" OEM 275/65/18 size is also the same diameter.
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
Op
I have several rams. Got one on 22s 2 on 20s and 1 on 17s. The 22s corner better, the 20s are the easiest to find as a replacement and the 17s are generally the cheapest and allow for more body sway/roll due to the larger sidewall.
All will work . I see a big ride difference in 22 to 20, due to road transfer via the wheel and seat. 17s are greatest for rough roads, 20s are great all around. If I'm on a several thousand mile road trip, 90% of the time, I'm in a ram on 20s. Hope this helps
JimmyC
Pittsburgh
Gotta love the internet. Lol!
BlueHemi1500
Richmond Va
I changed my tires from the factory 275/55/R20 to 275/60/R20 slightly taller sidewall, I did need to change the tire size which was very easy to do. It took longer to hook up the security bypass cable than to program the change.
BlueHemi1500
Edward Hands
Youngsville, Louisiana.
5.7 E-Torque
Did you make the switch?
How do you like it?
What one did you go with?
Any pics?
