wobblyboots
Hi from Australia, I have a 2020 1500 crew cab 5.7lt. Refueling is a real pain it takes for ever to fill, keeps clicking off. Used to work fine now it’s very slow. Anyone found a solution?
Do you ever wonder, "How the heck does this guy post this particular question in the Detailing subforum?"@wobblyboots it could be a problem with the rollover valve in the fuel tank. The rollover valve help keep the fuel in the tank if the vehicle ends up on its side or top.
Is the truck in question pictured in your Avatar?
Did it occur to you by reading my question I would like to know if he's asking about a Gen4 or Gen5 trucks so I would know which section to move this post into?Do you ever wonder, "How the heck does this guy post this particular question in the Detailing subforum?"
That doesn't actually matter. The answer is likely the same for most modern vehicles, regardless of make.Did it occur to you by reading my question I would like to know if he's asking about a Gen4 or Gen5 trucks so I would know which section to move this post into?
Smart people don't answer moderator's rhetorical questions..That doesn't actually matter. The answer is likely the same for most modern vehicles, regardless of make.
Yes that’s my truck@wobblyboots it could be a problem with the rollover valve in the fuel tank. The rollover valve help keep the fuel in the tank if the vehicle ends up on its side or top.
Thank you for the answer.Yes that’s my truck
