Radio wiring Diagram
ldevaul77
Lumber City, Georgia
Cummins
I have a 2018 Ram 2500 with the Alpine system and I'm trying to find a wiring schematic so I can use the subwoofer wires to run to the output converter. I'm running a skar active 2 channel line output converter and then to the amp. Thanks for any help.
SitKneelBend
St. Louis
3.6 Pentastar
I can't help much but I know the Alpine system has an OEM AMP. You'd be served well to search something like "add Amp/Sub to Alpine System". I know it's been discussed, but I'm not sure if you have to pull signal from the AMP or if you can pull a hi-level from one of the rear speakers.
RamDiver
Marlborough, Ontario, Canada
Need wiring diagram for 2008 Dodge Ram 2500 6.7L Mega Cab Laramie
Check this link for the full service manual.
